Old 03-14-2009, 07:04 AM   #1
roofing458
Retrofit a 350
have a chance to buy this engine it runs like a sewing machine no smoke ,no ticks no knocks still in the rv original truck 47k miles .i want to trans plant it my 66 4x4 C20 4 speed granny .it had a 283 now has a 292
1.What problems would i encounter with old granny tranny? motor mounts? ????
2.Is their a newer 4 spd trans i can also transplant or just leave old one
3.What should i do to engine before i transplant it.
4.Any advice on this trans plant would bevery helpful
thanks
the trans is suppose to work very good .anybody have use for it & offer
roofing458 is offline   Reply With Quote
Old 03-14-2009, 03:52 PM   #2
hewlett2002000
hewlett2002000's Avatar
Re: Retrofit a 350
i think it will bolt in place of the 292 just fine. the reason i say i think is because i remember reading somewhere that the passenger side motor mount is further back on the 292, but i could be wrong. it will bolt to your 4 speed with no problems. if its a good running 350 the only thing i would do is change the rear seal before dropping it in. im sure someone will chime in and let you know about the motor mounts.
good luck,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-14-2009, 04:10 PM   #3
roofing458
Re: Retrofit a 350
good luck,
John
I was thinking the same thing change the main rear seal ,rebuild the carb,clean it up paint it change water pump not looking for much speed with this truck just want to put a 8 back in it medium loud mufflers. Back in the day I would just drop it off & say I want it like this & pay .Well them days are long gone. Any other ideas or advice from all you pickup truck guys would be much appreciated .thanks kevin
Old 03-14-2009, 04:20 PM   #4
UltraBlue71
UltraBlue71's Avatar
Re: Retrofit a 350
Throw a K&N filter on her and a set of headers and run the wheels off her!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 03-14-2009, 04:58 PM   #5
62 short step
62 short step's Avatar
Re: Retrofit a 350
good luck,
John
Yeah, one of the motor mounts will not work can't remember which one. You will have to find another mount to drop the motor in correctly. Try pming littlered, he can tell you which one you will need.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-15-2009, 12:36 AM   #6
Captainfab
60-66 Nut
Re: Retrofit a 350
You should be able to just move the frame mount to the forward position (same as the other side) and bolt it down, and drop in the 350. That 350 will bolt up to your SM420 just fine, but you could swap to the newer SM465 if you wanted to. I agree on the rear main seal, water pump (your truck originally came with a short water pump) a set of headers, a K&N air filter, an HEI distributor, an aluminum intake and a good 4bbl carb of your choice.
Old 03-15-2009, 12:43 AM   #7
89 crew
Re: Retrofit a 350
If your block will accept it you should be able to use the 283 mounts and all will be fine! They are the same size blocks.
89 crew is offline   Reply With Quote
Old 03-15-2009, 08:40 AM   #8
roofing458
Re: Retrofit a 350
thanks you guys are the best.
