Old 03-14-2009, 01:48 PM   #1
wesmigletz
wesmigletz's Avatar
No limit FI tank vs the ECE FI Tank
I'm planning to swap a LSx engine into my 1971 truck. I would like to run an in-tank fuel pump. My first choice would be to run an in-tank pump in the tank behind the seat. If that isn't possible, I would run a blazer style tank with an in-tank pump.
Has anyone successfully installed an in-tank fuel pump in the stock, behind the seat on a 67-72 truck? Is it critical to use a baffled tank?
As far as blazer style tanks go, I have been considering either a No Limit or an ECE tank, but am open to other options.
No limit sells an EFI sumped tank and LS series fuel pump that will fit my 71 SWB. My only reservation is the aluminum construction. Should the tank being built of aluminum be a concern. Ideally, I would like the gas tank to out last me. The price is right on the No Limit gast tank, but I do not know anyone running run. http://www.nolimit.net/prodinfo.asp?number=TNK%2DEFI
From a search, the ECE Stainless Steel tanks seem pretty popular and well-built. I called ECE and they recommended their sumped tank, and then purchasing the GM ful pump for whichever vehicle the engine came out of. I asked, and was told that any of the common GM pumps would work. I don't have any experience whatsoever with late model engines and in-tank fuel pumps.
Can anyone with experience with the ECE tanks confirm the ability of the tanks to accept truck/Camaro/GTO in-tank pumps. Or, could you recommend a good fitting in-tank pump for an LSx engine?
TIA
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 03-14-2009, 03:42 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: No limit FI tank vs the ECE FI Tank
I have an stainless ECE tank in my 69 Burb. Very high quality and great fit. The company that builds the tank for them can tell you exactly what pump you need.
I also have an aluminum EFI tank in my 67 crewcab, it was built by boardmember FuelCellGuy. Once again, high quality and great fit.
I think it's just a matter of preference as for as stainless or aluminum. The aluminum is cheaper, but the stainless has the wow factor. They both will outlast your truck (and you!) more than likely, .
Hart_Rod is offline   Reply With Quote
Old 03-14-2009, 07:20 PM   #3
wesmigletz
wesmigletz's Avatar
Hart Rod, thank you for the information. Did you have to notch your frame for either of the tanks you used? Would you happen to still have the contact information for fuel cell guy?
Thanks again,
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 03-14-2009, 09:23 PM   #4
Hart_Rod
Hart_Rod's Avatar
Thanks again,
Wes
No notching required. I did remove the factory rear frame cross brace and installed the ECE rear brace. This gave me another couple inches of room. That was pretty much it, other than drilling the mounting holes. I don't have FuelCellGuys phone number, but you can look up his boardname and PM him with any questions.
R/
Old 03-14-2009, 11:34 PM   #5
wesmigletz
wesmigletz's Avatar
Hart Rod, thank you. Fuel Cell Guy's site is http://www.aluminumfuelcell.com/
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 03-18-2009, 10:24 PM   #6
wesmigletz
wesmigletz's Avatar
I ordered a tank from the Fuel Cell Guy Yesterday with an LSx pump. I will post pics when I get it installed.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 11-09-2009, 08:43 PM   #7
Thealien
Thealien's Avatar
Any updates on the tank/install?
