Old 03-14-2009, 03:19 PM   #1
bac1755
bac1755's Avatar
GM plug wires! Put them on the truck or use them to hang myself?
Ok i just put a motor from a 85 GMC in my 71 GMC. now I know there might be a little differance in wires for a points style ignition and an HEI, but not much. you would think after all these years GM could come up with plug wires that actualy fit. Instead you get wires that are to long, to short, and then wires that dont even belong in the kit. I have a rats nest of plug wires on this engine and dont like it one bit.
Does anyone out there know if you can buy a set of plug wires that fit.
bac1755 is offline   Reply With Quote
Old 03-14-2009, 03:28 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: GM plug wires! Put them on the truck or use them to hang myself?
are you buying wires that are specific to the 71 or to the 85? or neither?
I have always had better luck with buying "cut to fit" sets.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-14-2009, 03:29 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you have ram horn manifolds, and HEI, and want to route the wires under the manifolds (like stock) then you need the wire set ffor a 75 vette with a small block.
Old 03-14-2009, 03:29 PM   #4
'72customdeluxe
I just got a set of hei wires for a '78 truck with hei (that's the only way O'reilly's can find a part, making stuff up) and they don't fit right at all. All the msd stuff i've had works good. Plus they have cut to your own sizes kits.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 03-14-2009, 03:35 PM   #5
big_al_71
big_al_71's Avatar
I always use taylor wires and make them my self, 100% better than stock would ever be.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-14-2009, 04:00 PM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
I used these. The best plug wires I have ever had. They may seem a little pricey, but well worth the money.
http://www.jegs.com/i/Moroso/710/73602/10002/-1
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 03-14-2009, 04:31 PM   #7
cdowns
cdowns's Avatar
i buy taylor wires and make them to fit where i want them to go
Old 03-14-2009, 05:14 PM   #8
spinning wheels
spinning wheels's Avatar
Most reputable wire companies will make a set to fit your application. For the best fit, you should spend some money on spark plug wire guides. I have even seen, and used zip ties, just keep them away from the exhaust manifolds and from areas where rubbing will cause a hole or cut in the wires. This isn't rocket science, just common sense. Just stay away from some of the Vette plug wires, as some of the Vettes ran them thru the engine mounts. That was to keep them away from the exhaust, but what a PIA to install
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-14-2009, 09:28 PM   #9
elkynova
Just go and buy a set of whatever brand you want cut to fit wires and make them fit. I usually buy MSD because of their low resistence.
elkynova is offline   Reply With Quote
Old 03-15-2009, 01:39 PM   #10
bac1755
bac1755's Avatar
do the cut to fit work good? I bought a set one time and I just messed it all up, I was a lot younger and didnt have near the patience I do now. maybe I'll give them another try.
Old 03-15-2009, 01:46 PM   #11
bac1755
bac1755's Avatar
I did buy the set for a 85. Thanks for everyones help so far.
