Old 03-14-2009, 03:44 PM   #1
SOUTHERN917
Wrench Wench
SOUTHERN917's Avatar
Question Advice on headers please
I'm tired of looking at my rusty ramhorns, and want to buy new headers. I will admit to knowing very little about exaust systems, so here's where I need some input. I am running a 70 stock 350/th350 and want to know if there are any user friendly bolt on headers out there. I don't need "proformace" or "flashy", I just want something I can do myself without modifications. I've looked in summit & LMC, but I'm having trouble figuring out what I need. Thanks in advance for suggestions.
If everyone had good taste, who would buy all the FORDS?
Women join us!! BUSTED KNUCKLE BABES
"Face it girls, I'm older and have better insurance" -Fried green tomatoes
SOUTHERN917 is offline   Reply With Quote
Old 03-14-2009, 03:57 PM   #2
royo
royo's Avatar
Re: Advice on headers please
look around here
http://www.sandersonheaders.com/
nickle and dime
royo is offline   Reply With Quote
Old 03-14-2009, 04:34 PM   #3
cdowns
cdowns's Avatar
you could just take the ramshorns off and spend a few hours making them look pretty //easy to do and less than $20
Old 03-14-2009, 04:46 PM   #4
SOUTHERN917
Wrench Wench
I am wanting better access to plugs also.
Old 03-14-2009, 04:54 PM   #5
spinning wheels
spinning wheels's Avatar
Check out Eastwood Company. They sell all kinds of automotive paints and coatings. I know they sell some manifold hi-temp paints.
As far as headers are concerned. Do Not go the cheap route, unless you like exhaust leaks and using a BFH to get them in your truck. Most cheap headers won't fit right and can cause more headaches than they are worth. Such as, fried starters and the fore mentioned exhaust leaks.
If you do go with headers, spend the extra on ceramic coated headers. They keep the underhood temps down.
Hope this info helps you make your decision.
Good luck
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-14-2009, 05:15 PM   #6
Hammer57
Sending her "south"
Hammer57's Avatar
Grey Ghost turned me on to a Hedman part # on some very nice shorties for my '69. #69640. Clear the motor mounts and have good plug clearance. Price is very reasonable through Summit.
Terry Hall
No such thing as a finished project
It's either in progress or SOLD
Hammer57 is offline   Reply With Quote
Old 03-14-2009, 09:05 PM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
Exhaust paints burn off pretty quick. Only way to get a durable finish is to ceramic or powder coat them.
texanidiot25 is offline   Reply With Quote
Old 03-14-2009, 09:16 PM   #8
fastom
That's right, it's Copper!!
fastom's Avatar
Try Early Classic, www.earlyclassic.com. Very nice, I love mine!!
fastom is offline   Reply With Quote
Old 03-14-2009, 09:24 PM   #9
elkynova
I took the headers off of my 72 k10, got tired of exhaust leaks and burned plug wires. I went back to ramhorns and have never been happier. I spent some time bead blasting and bought VHT cast iron exhaust/manifold paint. You have to clean them, and then paint them. After the paint has dried, you have to bake them in an oven or bolt them on and run the engine. Once they have been cured, the paint is heat, oil, and solvent proof, and looks like fresh cast iron. Mine have been on for almost 4 years and still look like new. Most headers offer worse plug access than ramhorns do.. If you go with ramhorns you can run your plug wires behind the engine and then come up thru the motor mounts and have all the wires hidden, Looks great..
elkynova is offline   Reply With Quote
Old 03-15-2009, 09:17 AM   #10
jholley
jholley's Avatar
Originally Posted by royo View Post
Just a tip for ya. The headers that ECE sells for our trucks are Sandersons, and cheaper than you can get them from Sanderson.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 03-15-2009, 02:29 PM   #11
Hammer57
Sending her "south"
Hammer57's Avatar
Good point!
Took my Hedmans to Calico Coatings in Denver, NC. Got their ceramic coating on mine (second set they've done for me). Great look plus THEY DON'T STAIN.
Terry Hall
Old 03-15-2009, 02:49 PM   #12
Green Machine
Green Machine's Avatar
Put the Hooker coated competition (not the super comps) on our 70. Fit great and no leaks so far.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-15-2009, 05:23 PM   #13
I don`t know if you can run full length or need 3/4 length.But,there`s alot of good choices.Headman Elites.I can`t recall the price,but i`ve had some 5 or so years and haven`t touched them.You can make manifolds look good.I think only a ceramic will hold up over any length of time.I`d like to do some Vette ramshorns.but,I`ve always done headers.
Old 03-15-2009, 05:31 PM   #14
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Heddman are cheaper than Sandersons. Sandersons are better quality. Ive used both. I have a set of Sandersons just like Fastom that are new in box I need to sell.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 03-15-2009, 06:55 PM   #15
SOUTHERN917
Wrench Wench
How do I figure out if I can use 3/4 or full length, or shortys?
