Old 03-14-2009, 07:07 PM   #1
Green Machine
Green Machine's Avatar
292 Alternator for sale
This is a stock alternator from a 1970 C30 with a 292. It has the thicker pulley setup needed for the 292. Don't know if the 250 has same setup or not. Was working when pulled, bearings seem OK, but I'd put a front bearing and brushes in it anyway just to be sure. I have not had this apart to inspect anything. No stripped holes or screws.
Numbers are 1100838 37A
9B11 12VNEG
EDIT - just re-checked ground screw on back has bad threads.
Now $30 shipped.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-15-2009, 03:05 PM   #2
Green Machine
Re: 292 Alternator for sale
Just rechecked the alternator, the ground screw on the back (not the hot wire) has bad threads so knocking off $5, $30 shipped.
Old 03-15-2009, 06:02 PM   #3
BCOWANWHEELS
I,ll go 12.00 shipped to 37664 for the pulley, nut and cooling fan. Pm me if your interested.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-17-2009, 08:54 PM   #4
Green Machine
Sold.
Old 03-17-2009, 09:07 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
How much is the offset on the thicker pulley compared to a standard pulley?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 03-17-2009, 11:03 PM   #6
Green Machine
Looks like right at 3/8 inch difference in the offset. Heres a couple of pics, hope that helps.
