Old 03-15-2009, 02:49 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
GMC to Chevy
Has anyone done the grill swap from GMC to a Chevy grill? difficult? pictures? you need any brackets? do i need a whole new rad support?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 03-15-2009, 05:35 AM   #2
Re: GMC to Chevy
If you want to change your somewhat unique special hansome GMC into a common everyday run of the mill Chevy we need to know what year Chevy grille you want.
69-72 Chevy fenders are different from GMCs.67/68 are the same.The core supports,center bar,wiring,& hood latches are different.If you are going from`69 GMC to 67/68 Chevy you need a 67/68 hood.67/68s have a gravel shield below the grille.If you are going to 67/68 you can use your core support and modify the headlight buckets.
Old 03-15-2009, 11:03 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: GMC to Chevy
basicly, the whole front clip, fenders, hood, core support, all as one piece.That's the easy way to do it.
Leaving it a GMC would be real easy, and make the truck cooler.
Old 03-15-2009, 11:49 AM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: GMC to Chevy
I'm assuming its a '69 since you have '69 GMC on your sig line. You can make it look like '68 Chevy without changing your fenders and radiator support, but you have to change the hood, the grill and the bumper. You will have have to drill out the GMC headlight bracket radiator bracket on the radiator support.
If you want it look like a '69 - '72 Chevy, you have to change the whole front clip like Andy said, but you can still use your hood. I feel you on wanting change the grill. I overwhelmingly prefer the Chevy's too. Just tell 'em you're giving your truck LASIK surgery!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-15-2009, 12:43 PM   #5
Ackattack
Ackattack's Avatar
Re: GMC to Chevy
you will also have to drill some holes for the headlight adjuster screws. I used a GMC core support for my 68 chevy and did this, comparing it with a rusted out 68 chevy core support.
Ackattack is offline   Reply With Quote
Old 03-15-2009, 01:26 PM   #6
Longhorn Man
Re: GMC to Chevy
the hood will only have to be swapped if you don't want the GMC lettering or holes to remain.
Old 03-15-2009, 01:50 PM   #7
Hoffman65burb
Re: GMC to Chevy
Ahh, ok, thanks for the info
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
