Old 03-15-2009, 08:56 AM   #1
pumpgas
pumpgas's Avatar
Shift indicator options w/OD
What options do we have if not running a tilt for a OD shift indicator I can't seem to find anything to work correctly? Any and all info would be great.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 03-15-2009, 09:04 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Shift indicator options w/OD
I think Flaming River sells a OD lens that will fit on the stock column.
Hart_Rod is offline   Reply With Quote
Old 03-15-2009, 09:38 AM   #3
pumpgas
pumpgas's Avatar
Would you happen to have a part #? I'll check around the FR site too.
Old 03-15-2009, 10:34 AM   #4
Hart_Rod
Hart_Rod's Avatar
Sorry, all of my stuff is in storagein FL. You might want to PM boardmember RETRO68, I know he does some custom work on columns.
r/
Old 03-15-2009, 10:40 AM   #5
pumpgas
pumpgas's Avatar
Cool thanks for the heads up I been looking at the FR site but nothing says it'll fit our columns.
Old 03-15-2009, 02:57 PM   #6
gumbudah
Not that you were asking about shift arms, but this might also be helpful
http://www.kugelkomponents.com/produ...shiftkits.html for your shift arm. I'm assuming you're going to a 700R4.
As far as the indicator goes, I have one, which I bought from www.brotherstrucks.com
It is part number BR00560 as you can find here:
http://www.brotherstrucks.com/products.asp?dept=659
Hope this helps!
gumbudah is offline   Reply With Quote
Old 03-15-2009, 06:19 PM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
classicparts.com also has a 4spd OD lense.
texanidiot25 is offline   Reply With Quote
Old 03-15-2009, 07:41 PM   #8
pumpgas
pumpgas's Avatar
For a non tilt column??
Is this what you were talking about??
http://www.classicparts.com/frame-truck-years.html
How will that work on the stock column do you have exsperience with these?
Old 03-15-2009, 08:51 PM   #9
texanidiot25
Eat My Rust
http://www.classicparts.com/prodinfo...&desc=(1947-87) Acrylic Shift Indicator w/Pointer-4spd
It looks just like the stock one, just unscrew the old and screw in the new.
Old 03-15-2009, 09:03 PM   #10
pumpgas
pumpgas's Avatar
Yes I saw that also but didn't know about the pointer deal working like the stock one. I will look more into this. I have also been kicking the idea around of getting an Ididit tilt column.
Old 03-15-2009, 09:09 PM   #11
texanidiot25
Eat My Rust
You don't have to use the pointer. The stock one is fine. All your really doing is changing the lense to line up with the shifter detents in the 700R4/200R4/4L60E transmission
