Old 03-15-2009, 05:20 PM   #1
allout
allout's Avatar
what do you think?
well im thinking about this..
http://phoenix.craigslist.org/evl/cto/1076281072.html
i could get it for $2000. But also he said it gets around 10-11mpg. any way i could get better mpg out of it?
thanks.
allout is offline   Reply With Quote
Old 03-15-2009, 05:31 PM   #2
Wrenchbender Ret
Re: what do you think?
Yes. With the right set up it should get 15 mph or better. First you would need to see what rear end ratio it has. You probably would need to change to higher gears or change the trans to an o-drive.Then some good tuning should bring it right up. That seems like a good buy.
Wrenchbender Ret is offline   Reply With Quote
Old 03-15-2009, 05:33 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
Decent truck for the money.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-15-2009, 05:48 PM   #4
cdowns
cdowns's Avatar
appears to b issues in the engine compartment //air doesnt work maybe compressor and mounts missing might have something to do with that then theres the looped heater hose so theres no heat either and the way that alt is sitting on the wrong side says there mount and use issues on that too //maybe it's driveable but not very far from the looks of it// still a pretty good price if in fact theres no rust but i'd b checking real close for bondo in the normal places and b rerady to put at least another thousand or so in order to make it roadworthy
