Old 03-15-2009, 07:33 PM   #1
fastcam1
Young gun
fastcam1's Avatar
got air?
i am going to be installing an air ride setup on my 67 that im buliding from the ground up and was wondering if there is any way to fill the bags without the compressor hooked up by using some kind of shutoff valve or something so i can roll the chassis on and off a trailer does anyone know if this is possible? thanks
fastcam1 is offline   Reply With Quote
Old 03-15-2009, 07:56 PM   #2
six5
six5's Avatar
Re: got air?
You can install schrader valves on each bag. Or one schrader valve with a T junction for two bags.
And let me be the first to say welcome to the forum.....!!!
-Dave
My 1965 build...http://67-72chevytrucks.com/vboard/s...d.php?t=331302
six5 is offline   Reply With Quote
Old 03-15-2009, 08:08 PM   #3
fastcam1
Young gun
fastcam1's Avatar
Re: got air?
thanks
Old 03-15-2009, 09:13 PM   #4
six5
six5's Avatar
Re: got air?
No problem. Post some pictures of your truck so we can see what your are building..........
-Dave
Old 03-15-2009, 10:12 PM   #5
Shane
Shane's Avatar
Re: got air?
i used a ball valve for the front two and another ball valve for the rear two ... put a quick connect on it ... hook up my compressor line ... open valve to inflate bags ... close valve and unhook compressor line ... fast too
Shane is offline   Reply With Quote
Old 03-15-2009, 11:34 PM   #6
Inverter
Inverter's Avatar
Re: got air?
Ball valves w/QD's ftw......
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 03-16-2009, 12:31 PM   #7
djw32
Re: got air?
Shane,
Do you have any pics of your setup? This sounds interesting...
David
djw32 is offline   Reply With Quote
Old 03-16-2009, 01:27 PM   #8
Shane
Shane's Avatar
Re: got air?
sorry, but no pics ... it's fairly simple, just run your lines to form a "T" and connect a ball valve to it on one side with a quick disconnect on the opposite side of the valve ... do this for both the front and the rear so you have control over each end ...
THIS IS FOR MOVING THE VEHICLE AROUND THE SHOP ONLY !
DO NOT USE THIS SET-UP FOR ON-ROAD USE AS THE BALL VALVES WILL AND DO LEAK DOWN.
