Old 03-15-2009, 08:31 PM   #1
jkade
jkade's Avatar
Axle Saddles for 3.25" Tube (ford 8.8)
These came from ECE and I sanded them down to fit a ford 8.8 but ended up doing a 4 link. $20 shipped..
jkade is offline   Reply With Quote
Old 03-15-2009, 09:27 PM   #2
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: Axle Saddles for 3.25" Tube (ford 8.8)
I'm interested in these-do these make a 8.8 fit onto a swingarm? Do you have the panhard bar mount also?
chuckmc8 is offline   Reply With Quote
Old 03-15-2009, 09:47 PM   #3
jkade
jkade's Avatar
These will make a 8.8 fit the factory trailing arms. You can get a weld on panhard bar mount from *****************
Old 03-16-2009, 12:19 PM   #4
chuckmc8
chuckmc8's Avatar
how did you modify these to fit the 8.8? Axle diameter?
Old 03-16-2009, 12:29 PM   #5
lo72
Truck Junkie
lo72's Avatar
You can take a die grinder to open them up to fit the tube. Pick up a track bar from ECE and your in business
lo72 is offline   Reply With Quote
Old 03-16-2009, 06:08 PM   #6
jkade
jkade's Avatar
Die grinder and belt sander.. they arn't perfect but they will get the job done and you can't buy them anywhere else.
Old 03-16-2009, 07:52 PM   #7
chuckmc8
chuckmc8's Avatar
Thanks-I'm found a regular 5 lug rear that I'm gonna use so I'll pass on these-TTT for a great deal
