Old 12-17-2002, 10:22 PM   #1
72K10
Question Engine misses
My engine "misses" under load. For example, when I shift from high rpm 3rd gear to low rpm 4th gear, it usually misses, sometimes a series of "misses." Or 3rd gear going up a hill at lower speeds.
Got a recently rebuilt 350 with newer edelbrock performer intake, newer edelbrock 600 cfm carb with electric choke, newer summit HEI.
Any ideas on what might be causing this?
Thanks, Chris
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 12-18-2002, 01:34 AM   #2
jostrans68
Jostrans68
jostrans68's Avatar
I had similar problem found the valves were a shade to tight re adjusted and it went away
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 12-18-2002, 01:49 AM   #3
mikep
Used to have a truck
mikep's Avatar
too cold a range of plugs will do that too. What are you using for plugs? Ive been using AC 43 TS's gapped at .055" after a similar problem with a colder range plug that had occasional miss problems.
No truck :-(
mikep is offline   Reply With Quote
Old 12-18-2002, 04:04 AM   #4
Hooter
My other Love
Hooter's Avatar
Id check your timing. Might be a bit retarded. Try re gapping your plugs, maybe make the gap a bit wider. Your truck could also be a bit cold. Is your choke working properly?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-18-2002, 07:20 AM   #5
72K10
Thanks for the replies - some good advice. I checked the timing, it's dead on. The problem is a new one, so I'm inclined to think that it might not be the valves. I'll check the plugs, though, appreciate the tip on the hotter plugs.
Could it be fuel? I thought that maybe my fuel pump was going south. Choke could be it, but it's a fairly new Edelbrock with electric choke.
Thanks,
Chris
RLTW
70C10
72K10
72K10 Cheyenne
