03-15-2009, 09:54 PM | #1 |
Front End Rattle
I have a nasty rattling when I take on a bump... seems to be coming from the front driver wheel, or the underside of the front end suspension. Visually everything looks OK,... any ideas what problem could be hiding?
03-15-2009, 10:22 PM | #2 |
Re: Front End Rattle
Brake pads can rattle . Try the same bumps with a light pressure on the brake pedal . If it is still there , check the shock mounts and the swaybar bushings if you have one . Just a couple thoughts .
Frank
Born and proudly residing in a Red State ! |
03-15-2009, 10:37 PM | #3 |
Robert Olson Transport
what you need to do is jack up the front of the truck and do a front end check.. have a friend wiggle it back and forth with one wheel up in the air and see if you have play... take a large bar and stick it under the wheel and wiggle it to see if the ball joints have play.. same with the control arms
parts are cheap enough it wont take alot of $$$ to fit it
03-16-2009, 08:07 AM | #4 |
One shot, one kill.
I hate to add this but I will. How does it steer? Check for broken metal where the steering box bolts up and check the radiator support mounts. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
03-16-2009, 09:09 AM | #5 |
Radiator support mounts are good... just put in a new radiator.
I took a good look underneath, and nothing looks broken or out of place. Could it be a broken coil spring? It's not leaning of sagging, but though that might be the case (and a good excuse to get some drop springs!) It does steer good too... all the linkage checks out ok. |
03-16-2009, 01:38 PM | #6 | |
I have car A.D.D.
03-16-2009, 01:55 PM | #7 |
03-16-2009, 10:28 PM | #8 |
Hey
check your front shocks. I had one come loose where it bolts to the frame and it drove me crazy tll I figured it out rattled like mad tightened it up and no problem since good luck Mark
the avatar was my 62 I owned for 27 years 84 chevy short short bed black 84 gmc long bed copper/ buckskin 88 chevy k5 blazer white Life's short make the most of it Mark aka impalmark |
03-17-2009, 10:59 PM | #9 |
Frank, I think that was it... it does not rattle when I"m on the brakes over the bumps.
So you think its the brake pads themselves? Or a loose caliper? |
