side exit duel exhuast pics
any one has a pic of the under side of there truck with duel side exits? i was just woundering how peaple hanged them. i also have no idea on how to get a round the tank.
right now i have varry poorly done duel exhuast that is wire tided to the receiver hitch
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels ![]() 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
Another Day, Another Dollar
Re: side exit duel exhuast pics
mine is bolted up the the frame via an exaust clamp, and 2 peices of steel connected in the middle by a peice of thick rubber.
works like a charm
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square"
clear the tank fine? thats my only woury.
That's what i'm gonna be doing in a week or two. The one on the tank side, my passenger side will just be alittle lower.
post pics when you do it. i have also thought abought having both come out the driver side
![]() Join Date: Dec 2008
Really crappy pictures, but you can see how its done. I have dual 3 inch exhaust. It is hung from the crossmember under the bed. The brackets were bolted to existing holes in the crossmember. The pipes sit about two inches below the bedsides and there is about three inches of clearance around the gas tank in the closest spot.
| Bookmarks |
