Old 03-16-2009, 08:35 AM   #1
71C10SWB
71C10SWB's Avatar
Upper rear spring cups, reproductions?
Hey guys,
I'm new to the board. I just brought home my new '71 swb last weekend and I need to get rear coils on it. When I got it, the rear coils were removed and it was sitting on the overloads. I need to know if you can buy the upper cup that the coils fit into. The ones that are on it are rusted beyond recognition. I could build some, if needed. I have a set of coils and I still need to order the lower clamp plates, so if I could get the upper cups at the same ime, it would speed up the process.
Thanks,
Brent
71C10SWB is offline   Reply With Quote
Old 03-16-2009, 09:13 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Upper rear spring cups, reproductions?
Check with early classic enterprises
http://www.earlyclassic.com/
I believe they will have what you are looking for - I know I just bought the lower cups from them
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-16-2009, 01:32 PM   #3
truckintexas
CutlassSMan, Sent you a PM.............
truckintexas is offline   Reply With Quote
