Old 03-16-2009, 11:41 AM   #1
stunna
Boxed Frames
i need pics of trucks with boxed frames, mostly need rear shots with a C notched frame for lowering. Also want to see how u ran the brake, fuel lines etc. Thanks in advance!
stunna is offline   Reply With Quote
Old 03-17-2009, 10:31 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Boxed Frames
I don't have a full frame that is boxed, just a C-notch. Maybe one of our resident suspension pro's will have some on file.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-17-2009, 01:59 PM   #3
abadsvt
abadsvt's Avatar
Re: Boxed Frames
Here is a pretty trick boxed frame. They ran alot of the brake lines, fuel lines and so on in the frame. Pretty sweet. Here is a link. Near the bottom of the page shows some before pics. http://www.highgearhotrods.com/retro...%20gallery.htm
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-17-2009, 06:52 PM   #4
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Boxed Frames
Josh
That's a neat idea, I have a couple questions;
After running the brake and fuel lines then boxing, does the heat from the welder affect the lines?
How would you run your electrical if you were to install a new harness?
Tri5
Tri5Nerd is offline   Reply With Quote
Old 03-17-2009, 08:59 PM   #5
Shane
Shane's Avatar
Re: Boxed Frames
How would you repair a leaking brake line after it's sealed inside the frame rails?
Shane is offline   Reply With Quote
Old 03-18-2009, 12:07 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Boxed Frames
Better make darn sure nothing leaks "before" closing up the frame.
Articles-
"Refining Sierra"
Old 03-18-2009, 12:14 AM   #7
bentfab
bentfab's Avatar
Re: Boxed Frames
How would you know it leaked in the first place?
bentfab is offline   Reply With Quote
Old 03-18-2009, 08:13 AM   #8
Bob@ProAuto
Re: Boxed Frames
Maybe it's just me, but I like the important things where I can get to them, if needed.
I know everyone likes that "clean & smooth" look, but have you ever had a brake line go bad on your daily driver? Or had to replace a fuel filter that in the line?
I think that if you take the time to do a nice, neat (no thumb bends) layout on your lines, the final product is just as nice. And you can work on it too.
Burying them in boxed rails would make me extremely cautious if I had to drill a hole or if a line clamp came loose and caused a line to vibrate and rub a hole in itself........
Bob@ProAuto is offline   Reply With Quote
Old 03-18-2009, 10:29 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Boxed Frames
If your building a true show vehicle that will be on display, then the time and effort to run the lines inside a boxed frame might be the way to go.
For the more common show and go vehicle routing the lines inside an un-boxed frame hide them quite nicely.
If you really want a boxed frame, the can still be routed nicely on the outside of the inner rails and look just a good.
Here's a nice example or two from our resident tubing expert-bentfab
Articles-
"Refining Sierra"
Old 03-18-2009, 11:17 AM   #10
bentfab
bentfab's Avatar
Re: Boxed Frames
Thanks Man !!!
Old 03-18-2009, 08:18 PM   #11
Shane
Shane's Avatar
Re: Boxed Frames
Brake fluid level would drop over time.
Old 03-18-2009, 09:20 PM   #12
fixit-p
fixit-p's Avatar
Re: Boxed Frames
Dam...never thought I would be jealous of a pink under carriage.
fixit-p is offline   Reply With Quote
Old 03-18-2009, 10:05 PM   #13
nuke1
nuke1's Avatar
Re: Boxed Frames
Here is mine
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-18-2009, 10:48 PM   #14
bentfab
bentfab's Avatar
Re: Boxed Frames
I think you would loose a brake pedal before you relize your brake fluid is low.
Old 03-19-2009, 12:34 AM   #15
Shane
Shane's Avatar
Re: Boxed Frames
A slow leak would not necessarily equate to a softer pedal.
Old 03-19-2009, 12:44 AM   #16
bentfab
bentfab's Avatar
Re: Boxed Frames
Correct. But when your brake fluid is gone you have no pedal and not knowing when your loosing fluid is the problem. I know because I lost my brakes in my 64 when it still had drums on all 4's. Pushed on the pedal and no brakes !!! Got lucky cause the light changed green right before I got to the signal. Come to find out the front soft line got a hole from age.
Old 03-19-2009, 11:09 AM   #17
Shane
Shane's Avatar
Re: Boxed Frames
Same thing happen to me in a '65 I had back in high school (wish i still had that one) ... except it was a rear wheel cylinder ... I swear the truck felt like it picked up speed once I hit the woah-pedal!
Old 03-19-2009, 07:37 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Boxed Frames
.... ... I swear the truck felt like it picked up speed once I hit the woah-pedal!
That will make you ruin a good pair of short....
Articles-
"Refining Sierra"
Old 03-19-2009, 10:24 PM   #19
Shane
Shane's Avatar
Re: Boxed Frames
You got that right!
Old 03-20-2009, 01:05 AM   #20
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Boxed Frames
had that happen on a snowy gravel road in a monte carlo.only had front brakes and couldn't turn at all for the corning that was coming up. went right into the ditch and high centered the car on the snow pack.
luckily it was at a slow speed.
damn ford had to pull me out.
IvelDesigns is offline   Reply With Quote
