Old 03-16-2009, 12:25 PM   #1
72c10lover16
72c10lover16's Avatar
Camaro 4 speed?
I had an idea sitting in class today. i want to switch my truck over to a 4 speed but it seems like stock 4 speeds in these trucks are just so low geared. do you think it would be possible to put an old camaro 4 speed in one of these trucks?
68 swb 4x4 327 4 speed
72c10lover16 is offline   Reply With Quote
Old 03-16-2009, 01:30 PM   #2
Mayo
Cool Truck
Mayo's Avatar
Re: Camaro 4 speed?
I had a 4 speed out of an 80 Camaro in my truck up until a couple of weeks ago. It worked pretty good even though I only had 2nd, 3rd, and 4th gear. The only problem was that it was turning very high RPMs down the highway at 60 mph because my truck has a steep rear gear. That tranny took a dump in January so I got a 5 speed out of an 84 Camaro and it has been a good transmission. And if you do go with a Camaro 4 speed, you will need either bucket seats or a custom bent shifter.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 03-16-2009, 02:12 PM   #3
72c10lover16
Re: Camaro 4 speed?
how much work was it to switch them? my truck is an auto right now. i have another 69 thts a real peice but its a 4 speed so i know i could take some parts from it.
Old 03-17-2009, 12:01 PM   #4
Mayo
Cool Truck
Mayo's Avatar
Re: Camaro 4 speed?
When I bought the truck two years ago it had the Camaro 4 speed in it. It wasn't hard to swap to the 5 speed though. I just had to get a new clutch, cut in hole in the floor, and get my driveshaft shortened and get a longer speedometer cable.
Old 03-17-2009, 12:39 PM   #5
mr48chev
mr48chev's Avatar
Re: Camaro 4 speed?
The easy way would be to find a truck in a wrecking yard that had all of the standard shift pieces on it and get what you need.
Clutch pedal and linkage
Bell housing
Clutch fork
flywheel
clutch (even if you only use it as a core)
It's not hard but it is time consuming.
Old 03-17-2009, 12:43 PM   #6
mr48chev
mr48chev's Avatar
Re: Camaro 4 speed?
It would take transferring the needed parts from one truck to the other.
You would probably have an easy time of it if you had both trucks side by side, pulled the piece and cleaned it and moved it to the other truck while how it came off was fresh in your mind.
Unless you already have the car 4 speed I'd vote for the 5 speed these days to get the overdrive 5th gear.
Old 03-17-2009, 02:55 PM   #7
69lemans
Re: Camaro 4 speed?
If your trucks an automatic now,you'll also have to change the crossmember/trans mount
69lemans is offline   Reply With Quote
Old 03-18-2009, 02:05 PM   #8
72c10lover16
Re: Camaro 4 speed?
I have a 69 chevy pickup too that is already a 4 speed straight six i was gonna take the main components from that. like the pedals linkage trans crossmember ect.
Old 03-18-2009, 02:23 PM   #9
fnoblitt
fnoblitt's Avatar
Re: Camaro 4 speed?
i put a car 4 speed in my 70 pickup, hurst makes a shifter that fits with the bench seat(just barley). my truck was originally a 3 speed so it just bolted right up.
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 03-18-2009, 02:29 PM   #10
72c10lover16
Re: Camaro 4 speed?
what was the trans you used out of. Does it work well with the truck
Old 03-18-2009, 03:42 PM   #11
fnoblitt
fnoblitt's Avatar
Re: Camaro 4 speed?
i used a muncie m20 (wide ratio) trans, that i had sitting around . it works very well with my combination (rear gear ratio,tire size,engine torque,weight,ect.) i'm very happy with it.
Old 03-18-2009, 07:05 PM   #12
LONGHAIR
Re: Camaro 4 speed?
Even with the wide ratio box, you are still only looking at a 2.52-1 first gear and a pretty big drop to 1.88-1 in second. It takes quite a bit of rear end gear to make this work in a truck, which is much heavier then the car these transmissions were designed for.....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-19-2009, 07:01 AM   #13
lo72
Truck Junkie
lo72's Avatar
Re: Camaro 4 speed?
If you swap out the tailhousing on the Camaro 5 speed with one from a s-10 it will move the shifter forward almost to the stock position...the only issue will be with the speedo gear it will need to be moved to match up with the s-10 rear housing
lo72 is offline   Reply With Quote
