Old 03-16-2009, 12:27 PM   #1
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Need ideas for my inside door panels
I need some inspiration for my door panels. I've got 3 different styles to choose from. I'm thinking of not using the factory arm rest and create my own. I just need some ideas and pics.
Alan's Classic is offline   Reply With Quote
Old 03-16-2009, 05:34 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Need ideas for my inside door panels
paint them white-or whatever your seat color is,grey?- then paint the stripe body color-orange.
the center I would cut out a piece of fiber board,1/8 inch? and then upolster it with the same material/pattern as the seat.
1959-64 impalas have a neat stylized armrest, that might be neat.
if you could incorperate the door handle from those same cars (maybe by relocating the mechanism, or using one out of the same car as thearm rest), that might look cool as well.
this style armrest with the door handle, is in lots of the 59-64 gm's buick , caddy , pont., chevy, and olds.
there are all different lengths, depending if it is earlier, later, 2, or 4 door.
Old 03-16-2009, 05:38 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Shag carpet, or maybe some Troll hair............
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-16-2009, 05:47 PM   #4
jchav62
1962 C-10
jchav62's Avatar
I painted mine white and had my buddy pinstriped them for me...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-16-2009, 06:07 PM   #5
jonzcustomshop
1961 crewcab
^ that looks cheap & easy!
I have seen several different factory patterns... some with just the stripe painted white, some with the center painted white, and some with the stripe and center painted white.
\/ \/ might be cool to put a cloth insert on the lower panel as well, and maybe repeat the stripe pattern...
Old 03-16-2009, 06:30 PM   #6
Alan's Classic
Thanks for the ideas guys. I'll look around work for some more ideas as well.
Old 03-16-2009, 08:23 PM   #7
willyp
willyp's Avatar
man those are bad ass!
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 03-16-2009, 09:14 PM   #8
vin63
It's Better With Nitro
vin63's Avatar
Here are the door panels for my '63. I found a pair of door panels that weren't in such good shape (to eventually cover). I carved the arm rests from wood and attached them in just about the same spot as where the originals would mount - a little closer to the rear of the panel. Then I covered the door panels in foam and then eventually the same leather as my bench seat.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-16-2009, 09:27 PM   #9
SlimPikins
SlimPikins's Avatar
Those are totally cool!
I wish I had that kind of talent!
SlimPikins is offline   Reply With Quote
Old 03-16-2009, 09:28 PM   #10
Big Fenders
VIN63 That is nice work...
Bob
Big Fenders is offline   Reply With Quote
Old 03-16-2009, 10:07 PM   #11
aboz
aboz's Avatar
That's the nicest '63 door panels I've ever seen! What thickness of foam did you use and do you have your original pattern that I can get for the leather skin? My idea was to powder coat my panels in a black wrinkle finish along with my dash but you've got me thinking otherwise. Where can I see pics of the rest of your ride?
ABOZ
aboz is offline   Reply With Quote
Old 03-16-2009, 10:19 PM   #12
SIR
SIR
SIR's Avatar
we just went for a simple look......
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 03-16-2009, 10:26 PM   #13
vin63
vin63's Avatar
Bob
Thanks...my experiment turned out a lot better than I had planned. Much thanks to my mom-in-law for stitching the curved patterns I drew for the center section. I just used some leftover higher density headliner foam (1/2-inch I think - it's been about 6 years now) that was given to me. All I really did was follow the contour of the original door panel since I like the shape. I was just lucky with the spray glue gun that weekend.
Old 03-16-2009, 11:10 PM   #14
Alan's Classic
Awesome ideas here. Vin those look great. I had thought about something like that. I have alot of patience, but I think I would run out of patience doing something like that. I guess I could paint them for now and once I get the truck done and the seats covered I could try something like that. But then again I want to do subtle changes. I know the dash is a big change, but most people will think it is factory.
Old 03-16-2009, 11:23 PM   #15
4dranch
Shloooooong bed member #2
4dranch's Avatar
x2,,Joe
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-17-2009, 09:19 AM   #16
jchav62
1962 C-10
jchav62's Avatar
Originally Posted by 4dranch View Post
x2,,Joe
Thanks guys! Here's a couple pics of the panels installed...
Joseph Chavez
Old 03-17-2009, 10:06 AM   #17
jason65
Registerd User
jason65's Avatar
Now I'm gonna have to do something with mine to. Those look cool.
jason65 is offline   Reply With Quote
Old 03-17-2009, 10:31 AM   #18
Joey~AP
TexasBowhunter
Joey~AP's Avatar
I used 3M Adhesive spray and squeegeed fabric on mine.
Joey~AP is offline   Reply With Quote
Old 03-17-2009, 03:19 PM   #19
slepysal
slepysal's Avatar
SWEET !!!
Hey Vin how about a "how to"?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-17-2009, 07:41 PM   #20
vin63
vin63's Avatar
Originally Posted by slepysal View Post
SWEET !!!
I think a person has to know what they're doing to write a how-to.
Here's kind of what I did: It was a total experiment on my part to see if I could cover the door panel in the same leather (leftover) from my seat. I used 2x4 lumber and carved mirror images of the arm rest shape that I thought would be functional. I wittled out the recess for the pull insert. I bolted the arm rests to the panels and used some old sheets I was using a drop cloths to make my patterns. My mother-in-law stitched the a two-piece pattern for the arm rest bulge and then I trimmed the sheet for the overall pattern and marked the decorative stitch patterns. I then started to trim the foam around the existing shapes of the panel, leaving gaps to accentuate the center embossed pattern. Then I proceeded to get a buzz from the fumes of the spray adhesive.
Old 03-18-2009, 11:09 PM   #21
ElkyRacer
SIR, looks good, more pix of the interior? Looks like you have a good looking combo going in there.
ElkyRacer is offline   Reply With Quote
Old 03-20-2009, 03:14 PM   #22
slepysal
slepysal's Avatar
Well looks like I have another project !!
Old 03-20-2009, 03:53 PM   #23
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Man-o-man, those are B A D !
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
