Old 03-16-2009, 12:50 PM   #1
69lemans
need help with pulley alignment-250-6 pwr steering
I want to add power steering to my truck while I have it torn apart and everything is easy to get to. It's a 72 with stock 250-I6. I bought the power steering pump and pulleys from a salvage yard in another state over the phone,so I didn't see them mounted on the car they came off of,don't even know what they came off of. When I bolted everything on my engine,ALL the pulleys line up-alternator,water pump and power steering. I already had a double pulley on my crank as this is a replacement engine ,and I have the double pulley for the water pump,but is it correct that the water pump alternator and pwr stg pump should all run off the same belt? All help is appreciated.
69lemans is offline   Reply With Quote
Old 03-16-2009, 02:16 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: need help with pulley alignment-250-6 pwr steering
Seems like you're missing some brackets. Check the following thread. You can also do a search on "six cylinder power steering" and find some more info.
http://67-72chevytrucks.com/vboard/s...power+steering
68gmsee is offline   Reply With Quote
