broken/ disconnected hood latch cable
I just went to open the hood to swap my plugs and wires, but there was no tension on the pull. How do I get it open to fix it?
90 squarebody suburban by the way.
____________________________________ Last edited by trenchwarfare; 03-16-2009 at 01:27 PM. |
the pollock
Re: broken/ disconnected hood latch cable
patience and a screwdeiver
that's how i have gotten mine before now the cable usually runs by your inner fender on the drivers side, sometimes you can reach up and see if you can pull it down .. if it's connected you'll be set.. if it's not.. patience and a screwdriver =-)
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
the pollock
oh p.s. it coul be partially released hence why there's "no tension" have a buddy "pop" on the hooda little to see if that's the issue while you hold the latch...
good luck
Yeah, it was just sticking again. I lubed up the latch and I'm going to adjust it when i change my plug wires tomorrow. Thanks for the advice and good thing i didn't have to use it.
____________________________________ |
the pollock
hey dude "pb blaster" penatrating catalyst and a wire brush...
that'll keep er clean for a while
