![]() Join Date: Jul 2008
e-brake cable removal
i am taking my rear end out and i am stuck on getting my e-brake cables off of where they are connected to the trailing arms. and advice would be great!
The Older Generation
Re: e-brake cable removal
There should be a small clip or retainer on the cable housing, on the front side of the bracket on the trailing arms. If you remove the clip and slide the cable back it will slide out of the slot. This is one of those things that is really hard to explain in a post so I hope it makes sense... ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-16-2009 at 11:23 PM. |
i took those clips off and it is a real pain to pull that cable back. i thought that is what you had to but i couldnt pull the cable back enough. im sure there is a little trick to doing it.
Never Ending Projects
Make sure your e-brake is not on and you should be able to pull the outer housing back far enough to unclip them from the brackets. Then you can get the slack to disconnect them from the metal connector that connects them to the front cable.
Worked fine for me.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#5 | |
#6 | |
Here's a pic showing mine removed. ![]() BTW, not you don't need to have the rear end unbolted first.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 03-18-2009 at 10:17 AM. |
Restoration Virgin!
not sure if this pic helps, but here ya go...
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
