Old 03-16-2009, 09:24 PM   #1
sourkraut
sourkraut's Avatar
Power Steering on 67'?
Does anybody know the measurement between the power steering box and the frame? I plan on putting power steering on the truck and need to make the bracket. I know that different companies have them available but that would be to easy! I am trying to do or make as much as I can myself.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 03-17-2009, 04:50 PM   #2
Mondo
Mondo's Avatar
Re: Power Steering on 67'?
I thought it bolted straight to the frame... on most 67s there's a dimple that needs to be made in the frame to allow the box to bolt directly.
Mondo is offline   Reply With Quote
Old 03-17-2009, 05:10 PM   #3
psychobilly451
I hope i don't side track the thread too much but....
Where does one find (rebuild) parts for the ram assist power steering?
1967 K20 Stepside Longbed 250-6 sm420
psychobilly451 is offline   Reply With Quote
Old 03-17-2009, 07:52 PM   #4
sourkraut
sourkraut's Avatar
you are 100% correct! I had did some research today and found that out. I have seen all the spacer/bracket advertised and thought I would have to move it out a little. but as you said I will have to dimple/releive the frame so it will fit flush on the frame. thanks, Mondo!
