Old 03-16-2009, 10:04 PM   #1
pinnedcr250f
Hood hinge corner sticks up
On my 1971 C10 my hood on the hinge side close to the driver stickes up about 1 inch. you can push it down to fit flush with the body but after driving it just does it again. Does anyone have a idea how to fix this?
Thanks big time!
John
71 Chevy C10
02 Chevy Dmax
06 Yahama Rhino:
pinnedcr250f is offline   Reply With Quote
Old 03-16-2009, 10:30 PM   #2
nvr_di
nvr_di's Avatar
Re: Hood hinge corner sticks up
I'd like to know this too.
I have the same problem but it does it on both sides. After a while it will push the back of the hood up and the front down so much I cant get my fingers under the front to pop the hood.
nvr_di is offline   Reply With Quote
Old 03-16-2009, 10:34 PM   #3
chrislehr
Engine n00b
chrislehr's Avatar
new hinges.
chrislehr is offline   Reply With Quote
Old 03-16-2009, 10:38 PM   #4
white72c10
white72c10's Avatar
Need new hinges. I replaced the springs on mine hoping to fix the problem but it needs hinges.
white72c10 is offline   Reply With Quote
Old 03-16-2009, 11:16 PM   #5
Green Machine
Green Machine's Avatar
Try adjusting first, I think the back of the hinge needs to go lower, but you'll have to play with it. If that doesn't work then new or good used hinges should do it as mentioned.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-16-2009, 11:17 PM   #6
tim21391
tim21391's Avatar
agree with white72c10.. mine did that when i had the hood on... they just get weak... new hinges will go on mine when im ready to put hood on
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-16-2009, 11:18 PM   #7
boogie67
boogie67's Avatar
My sons 72 use to do that and i loosen the bolts on the hinge that go to the fender.I then pushed the hood as far up as it would go and tighten the bolts it worked.The hood set even then.Ithink I learned that from this site somebody else did it.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 03-16-2009, 11:52 PM   #8
nvr_di
nvr_di's Avatar
Originally Posted by chrislehr View Post
new hinges.
aw crap..
Old 03-17-2009, 06:21 AM   #9
Shock_Me
Shock_Me's Avatar
There's an adjustment procedure somewhere in the FAQ section. The same thing boogie67 mentioned. I've done it on three different trucks, and it worked every time. You are essentially pre-loading the springs so the hood pops up a bit when you press the hood release lever. It will lower the rear of the hood at the same time.
Try it, it may work for you too.
Pete
Shock_Me is offline   Reply With Quote
Old 03-17-2009, 05:02 PM   #10
nvr_di
nvr_di's Avatar
boogie67 & Shock_me this is what you are talking about right?
http://www.67-72chevytrucks.com/vboa...d.php?t=319778
Originally Posted by Huck View Post
Open hood. Hold in open position. Have someone loosen the rear two hinge to fender bolts and loosen the front one just a tad. Push hood up till the hinges rotate backward a bit. Tighten rear bolts on both hinges. Check alignment as you lower hood.
I'll definitely give that a try Thanks guys!
Old 03-17-2009, 05:47 PM   #11
boogie67
boogie67's Avatar
nvr di Thats it.good luck
Old 03-18-2009, 10:13 PM   #12
mjensen
mjensen's Avatar
After my old hinges broke, I bought a set of used ones (VERY BAD IDEA). I bought some new ones and they work a lot better. After installing these though, it stuck up about 1/2", so I tried the alignment trick noted in the posting above. It actually lays flat, and aligns better, but I still have to push the corners down to get it to line up with the cowl. I did notice that these new hinges seem "stiff" and the hood has a lot of flex when opening and closing. Is this normal? Would it help to lube the hinges more?
On another note, now that it has new hinges, the hood doesn't line up with the crooked front end
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-18-2009, 10:16 PM   #13
Number98
Prestige Worldwide
Number98's Avatar
I was able to buy new springs and then adjust the old hinges a bit on a 68 I had.... fixed it right up.
Number98 is offline   Reply With Quote
Old 03-19-2009, 08:18 PM   #14
mjensen
mjensen's Avatar
Anybody have an answer for me?
Mike
Old 03-19-2009, 08:52 PM   #15
Sinister
Between Trucks...
Sinister's Avatar
Lube em up, I used WD-40. They'll loosen up.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-19-2009, 08:57 PM   #16
El Jay
Gone to greener pastures
Not sure about your question.
But, you can adjust the hood fore/aft by loosening the bolts on the "hood" side of the hinge.
As an example,if one side of the hood is too far back & not lining up with the front of the truck; loosen the bolts a bit & move the trailing edge of the hood "up" which would be forward, if the hood were closed.
It's not as difficult as it sounds. After replacing most of the front end sheet metal on my Chevy (with a lot of help from a few friends) I had to do the hood adjustment(s) alone. It took me maybe an hour to get the rear edge aligned with the cowl and the front of the hood lined up with the front of the fenders.
The air ratchet was a great help on that little project.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-20-2009, 08:07 AM   #17
Andy4639
Old member
Andy4639's Avatar
Just talked to Willie and they will be at Charlotte in April. He said they have set's of hinges already made up for exchange for your old ones. They are $150.00 with exchange for the Chrome looking ones with used springs. Springs are black, chome or plain metal your choice.
http://www.hoodhingerepair.com/services.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-20-2009, 09:45 AM   #18
LONGHAIR
YOu are going to have to adjust the fenders to line-up with the hood. The hood is in a fairly un-changeable place. It has to align with the cowl and sit squarely. The fenders just full the space between. Get the hood right and move the fenders to meet.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-20-2009, 12:15 PM   #19
WillW23
As Andy noted, I will be at the Charlotte Auto Fair, the first week in April. If you need rebuilt hinges, call ahead, so I can have what you need there, trade in or not.
Willie
willie@hoodhingerepair.com
WillW23 is offline   Reply With Quote
Old 03-20-2009, 12:43 PM   #20
Andy4639
Old member
Andy4639's Avatar
Hope you didn't mind the plug for you. I will be looking for you Thursday. I'll be the one carring two hood hinges with me.
