Old 03-16-2009, 10:27 PM   #1
67sss
67sss's Avatar
what are these called?
No prizes offered for the correct answer!
67sss is offline   Reply With Quote
Old 03-16-2009, 10:29 PM   #2
Joe67
67 is sold
Re: what are these called?
Blinker fluid tank retainers
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-16-2009, 10:37 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Those are check straps to control engine roll. The humped bracket bolts to the frame rail and the cable fastens to it and bolts to the engine.
LockDoc
Leon
Old 03-16-2009, 10:39 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, that was installed per a recall for broken motor mounts
Old 03-16-2009, 10:59 PM   #5
67sss
67sss's Avatar
thanks
Old 03-16-2009, 11:02 PM   #6
stockish shawn
what years and engine options, Ive had three a 68 69 & 70 never seen them before but it makes sense
stockish shawn is offline   Reply With Quote
Old 03-16-2009, 11:06 PM   #7
Critter
Future TOTM Winner
Critter's Avatar
I just pulled a set off of my 69 parts truck...350/th400 1/2ton lwb. I think alot of people probably pulled them off years ago when the motor was rebuilt. Plus if you use the new interlocking style motor mounts, you don't need them anyway.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 03-16-2009, 11:08 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
late 60's early 70's. That was a short lived recall until they redesigned the motor mount to the safety mount and then that was the replacement part. If you had a linkage type gas pedal you got that strap setup. Cable type pedals did'nt have the WOT problem.
dwcsr is offline   Reply With Quote
