Old 12-18-2002, 10:37 AM   #1
mt Al
Slow windshield wipers?
My wind shield wipers are really slowing down and seem to be stuggling just to get their job done. Any ideas? Is it tough to change the motor?
Thanks.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
Old 12-18-2002, 12:04 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Mine are too!. The motor is up under the dash pretty tight.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-18-2002, 12:25 PM   #3
Mudder
Mudder's Avatar
I found thats its really easy to get to the wiper motor with the cluster out. Make sure all the moving joints are lubed. I use the spray white grease. For what they are I think mine work great. You will have to remove the cowl.
Mudder is offline   Reply With Quote
Old 12-18-2002, 12:29 PM   #4
wnc mountain
More hobbies than money!
wnc mountain's Avatar
Hum! You guys have me wondering. I have never turned mine on in over a year. Maybe I should do that now and then.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 12-18-2002, 12:43 PM   #5
COBALT
COBALT's Avatar
Well, they're electric motors with moving mechanical parts. They need to be maintained just like anything else, and they're outside in the elements too!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 12-18-2002, 02:13 PM   #6
Leinie
I was just driving home in the rain with my sloooow wipers and noticed my volt meter was reading very low. I reached under the dash and jiggled some wires and the volt meter shot back to normal and the wipers sped up significantly.
Clean clean and tighten the wiring and see what happens.
I'm also going to lube under the cowl plate tonight and try to get rid of the squeaking.
Leinie is offline   Reply With Quote
Old 12-18-2002, 06:05 PM   #7
72K10
Mine slowed down when I had a short in my electrical system (dimmer switch) that caused a drop in available voltage. Once I fixed the short and got the juices flowing again, the wipers sped back up.
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 12-18-2002, 06:08 PM   #8
Mudder
Mudder's Avatar
I tried a pair of corvette wipers one time. They had the little wings on them. The air pushed them against the windshield so hard they wouldn't hardly move. Had to take them off.
