Old 03-16-2009, 10:39 PM   #1
hotvdub
hotvdub's Avatar
Biggest wheel and tire for a 69 LWB
Hey guys, my first post. Bought a rough 69 LWB and was wanting some wheel and tire advice.
Looking for the biggest wheel and tire combo with out frame/ bed mods.
Truck will be lowered 3" front and 5 " rear.
Going for a hot rod look so bigs and littles are fine.
Must be 6 lug. Drum or Disc if that will help.
hotvdub is offline   Reply With Quote
Old 03-16-2009, 10:51 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: Biggest wheel and tire for a 69 LWB
Currently I have a 31" x 10.5" tire on my '69, lowered 3". Would be a bit tall for a 5" droped truck, but the 265/70s I had while building and had 5" drop springs in back was about perfect diameter,but was pushing the width
texanidiot25 is offline   Reply With Quote
Old 03-17-2009, 01:11 AM   #3
71chevytruckguy
71chevytruckguy's Avatar
im running a 28x10.50 slick with a 15x10 wheel with 4" of backspacing. has 5 lug axles in it but the rearends still the same width. Think the backs lowered 4 inches. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
