70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Do I have to?
I want to do some work on my truck and am wondering if the box will stay on the truck if I remove the bedwood. I dont have lot of room to work on the truck and the bedwood needs to be changed out anyway.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Under Construction
Re: Do I have to?
The bed should stay on, there are 4 bolts i believe that bolt down through the cross member to bolt to the frame. you may want to replace those after the wood slats have been removed.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
LET'S GO...MOUNTAINEERS
Re: Do I have to?
Yes it will sit on the rails under the wood.
72 SWB/Step |
![]() ![]() Join Date: Jul 2002
Re: Do I have to?
I have only done one, but yes you can the wood without taking off the bed, but the if all the wood is remove at once the bed will drop the thickness on the wood onto the cross sills.
What I did was remove all the wood except one slat in the middle to keep everything up. I inserted the new wood on both edges drilled and coated. Then I removed the last old slat. I then put in all the new wood. If your wood is not precut, you may be pulling pieces in and out till the holes are drilled. Once all the holes are drilled and wood is treated then added the metal strips and bolts.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 03-17-2009 at 12:02 PM. |
Re: Do I have to?
Thanks for all the help guys. Knowing this will make things easier for me.
