1960 front suspension swap
Im planning on doing a front suspension swap on my '60 for a bag set-up, discs, and possibly power steering.
I have read on here about what year's will work as far as an "almost" direct bolt-in swap. my question is, does it make any difference if the "new" suspension/core support is off of a 1/2 ton or 3/4 ton? any other advice/warning will be greatly appreciated. thanks in advance. Chris |
#2 | |
Re: 1960 front suspension swap
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Agreed......I don't quite understand what the core support has to do with swapping a front suspension.
i'm trying to swap my torsion set-up for a later model spring style set-up. take the entire front suspension w core support and un-bolt old,....bolt in new...
the core support is the piece that holds the radiator
AKA radiator support. part number 5 in this pic ![]()
![]() ![]() Last edited by joe231; 03-18-2009 at 11:12 AM. |
[quote=joe231;3204546]the core support is the piece that holds the radiator
AKA radiator support. sorry, maybe i'm using the wrong word to describe what i mean... this is what i'm talking about... right or wrong i've always known this as the core supprt and referred to what you're pointing out as the rad. support/saddle. doesn't mean that i'm right tho. ![]() |
The Item that you have circled is the front suspension crossmember. Still the C20 crossmember is the same as C10. You can use the C20 A-arms but if you wish to swap to 5X5 you will need the C10 spindles and brakes. The core support is the item that Joe pointed out.
#9 | |
Cool. well, thanks for correcting me, you learn something new everyday.
one other question, i assume that the suspension crossmember is different for torsion bar and reaguler springs? thanks again guys! i appreciate it! Quote:
#10 | |
60-66 Nut
One of my buddies said he used the C20 suspension with the C10 spindles but, if he remembers correctly that the C20 lower control arm dose have a larger bore but that the taper on the ball joint is the same as C10 and he was able to use the C10 spindles. That also was on 73 up suspension with the rubber bushings. That was fifteen years ago so guess we need to verify.
Registerd User
I took the lower control arms off of a 69c10 and put my cross shafts in them and balljoints for a 84c10. The upper was no problem the 84 joint went right in. It's the idler are that gave me trouble. I forgot what year I had to use for that. But I had to lower the mount and drill out new holes.
#13 | |
60-66 Nut
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-20-2009 at 12:17 AM. |
#14 | |
#15 | |
60-66 Nut
