03-17-2009, 07:08 PM | #1 |
PITbut
Adding another fuse block?
I did a search and didnt have much luck. Im running my stock fuseblock right now and its in great shape. . I have to add probably an additional 10 power wires that need to be switched ignition fused wires.
2 compressors 4 guages kickdown switch electric choke. I want to add a fuseblock. just a simple setup with 5 or 6 fuses in it. I can run a relay to switched power to it and then i can power all of my additional stuff. You guys know of anywhere that sells something like this?? |
03-17-2009, 07:09 PM | #2 | |
PITbut
Re: Adding another fuse block?
http://www.wiringproducts.com/conten...d=39869.105556 |
03-17-2009, 07:28 PM | #3 | |
PITbut
http://www.painlessperformance.com/w...assic%20Trucks Anyone use this? Seems about 80 bucks ish.. This should work right? Ever since i found this site i feel like i need at least one other person to have used something im buying before i buy it. LOL..... |
03-17-2009, 07:30 PM | #4 |
Eat My Rust
I have a maxi-fuse block off some late model GM truck, bolts straight to the battery + terminal. I'm sure you can order one through GM, tell me if you need the part #
03-17-2009, 07:55 PM | #5 |
Between Trucks...
Try Summit or Jegs. I got one that added 4 fuses for $20, they have a ton of different sizes.
Beat it to fit, Paint it to match... |
03-17-2009, 09:35 PM | #6 |
Napa sells several different ones and most of the wiring kit outfits sell add on fuse blocks.
This one at Napa isn't cheap but has plenty of circuits and you should be able to get it overnight at most Napa stores if they don't stock it.. http://www.napaonline.com/MasterPage...ion=Fuse+Block |
03-19-2009, 08:56 PM | #7 | |
PITbut
03-20-2009, 07:42 AM | #8 |
Old member
I found a small fuse block at O riley's. It holds 8 newer type fuses and it screws into the fire wall. I'm going to use it for the lighter stuff such as radio amp stuff. It was $8.00
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-21-2009 at 10:42 AM. |
03-21-2009, 10:43 AM | #9 |
Old member
Here is a picture for it. Was like $8.00 for it. I'm going to putt all the switched ignition stuff on it.
03-21-2009, 10:58 AM | #10 | |
PITbut
03-21-2009, 11:01 AM | #11 |
Prestige Worldwide
I seen a while back where M&H would put together a new fuse box with any add-ons that you wanted for our trucks... I don't remember where I read it though, might be worth looking into.
03-21-2009, 11:02 AM | #12 |
Old member
The one I posted will run off the switched source also. Connect it to the new one with a heavy gauge wire to it and then run your other stuff off it. You could even run one over to the passenger side of the cab floor and have the rest hooked up there.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-21-2009 at 11:02 AM. |
03-21-2009, 11:56 AM | #13 |
Between Trucks...
If your going to run that many fuses I'd run it off a relay and have switched power turn it on.
03-21-2009, 12:07 PM | #14 |
PITbut
03-21-2009, 04:02 PM | #15 |
I used the Painless one you showed above for my EFI stuff, it works fine.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-21-2009, 04:59 PM | #16 |
Great thread. I need to do this too eventually.
Curry in a Hurry: SB rebuild for my 71 C20 |
03-21-2009, 08:25 PM | #17 |
I added a 6 circuit ato fuse panel to my existing panel. I also added a switch panel fed from the new fuse panel to switch each circuit on when needed. It works and costs $18.00. check it out at www.wire1hotrod.com Part # is 100-AG6. Been using it for three years with no problems. This particular fuse block has a common ground pad you can run the ground side of your circuits to. Finding a convenient ground isn't always that easy and this block is really handy.
