Old 03-17-2009, 07:43 PM   #1
1moretoy
4 link question
can i run 14in wide wheels in the rear of my 70 short step by narrowing my stock rearend and keeping my stock suspension. if not what 4 link kit would u recomend. i would like to run bags also thanks
1moretoy is offline   Reply With Quote
Old 03-17-2009, 09:30 PM   #2
6t9ls1
Re: 4 link question
Im not too sure about the 14 inch wide wheels I can tell you though for a 4 link kit you can go with 1 of suicide doors kits or get a hold of Nathan at Porterbuilt Streetrods. I havent heard or seen n e body using 14 inch wide wheels on a stepper. I have a buddy that was running a 12 inch on a fleetside and stock suspension.
1969 GMC Long bed 2wd-Work in Progress
1987 GMC Short bed 2wd- 283(lunati voodoo cam, aluminum intake, edelbrock 600 carb, headers, msd ignition), 700r4 w/2800 stall, 4.88 limited slip, more to come
6t9ls1 is offline   Reply With Quote
Old 03-17-2009, 10:28 PM   #3
Tagg33
Tagg33's Avatar
Re: 4 link question
I'm not sure about a 70 but if it helps I have 14" wide rims on my 84 with a 48" wide axle housing. My frame is not narrowed just the axle. I think it all depends on how low you want your truck. My 9" rear with ladder bars is for sale, PM me if you are interested in more details.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 03-19-2009, 10:14 PM   #4
1moretoy
Re: 4 link question
any 1 else
Old 03-19-2009, 10:32 PM   #5
Twisted Minis
Twisted Minis's Avatar
Re: 4 link question
Does your truck have leaf springs? My uncle built a 2WD blazer back in the day with 21" wide MT tires under the back, with stock frame rails. It had a custom length 9", but they inboarded the rear leafs so that sat inside the stock frame rail. Turned out pretty good. Widened the stock tubs too.
And I have no pictures, was a while back. I was sweeping floors then.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 03-20-2009, 08:56 PM   #6
1moretoy
Re: 4 link question
no it has coils i want to run the coy's c-5 wheel 20x14
