Old 03-17-2009, 09:46 PM   #1
6772owner
Gearhead
6772owner's Avatar
LT1 Question
Hey everybody with LT1's, I am having a problem getting my LT1 to start. I had the VATS programmed out of the ECU but it still doesnt seem to be firing the injectors. Anyone have any tips on troubleshooting this?
Thanks,
Clay
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 03-17-2009, 10:08 PM   #2
Elephanthead
Re: LT1 Question
Hmm, there is a guy on the corvette forum having the same problem, look in C4 tech tips to see if he finds a solution.
http://forums.corvetteforum.com/index.php
Elephanthead is offline   Reply With Quote
Old 03-18-2009, 12:59 PM   #3
6772owner
Gearhead
6772owner's Avatar
Re: LT1 Question
Ok thanks for the info, I posted up the question over there.
Old 03-18-2009, 02:55 PM   #4
ulakovic22
Re: LT1 Question
OBD1 or 2 LT1? Does it crank and not start or does it not crank at all? Have you verified fuel pressure at the rail, spark from the coil and the signals from the opti?
Go to this site and look around in the how to and component location links.
www.shbox.com
ulakovic22 is offline   Reply With Quote
Old 03-18-2009, 03:21 PM   #5
6772owner
Gearhead
6772owner's Avatar
Re: LT1 Question
Sorry it is OBD 2 (96') the engine cranks, but I bypassed the VATS for that anyway, I havent checked the pressure yet, but have used two different pumps with no success. I have spark because it will start on Starting Fluid. I dont know about the opti signals, I will look around. I put a brand new one on the engine while it was out so idk. thanks for the info.
Old 03-20-2009, 04:09 PM   #6
6772owner
Gearhead
6772owner's Avatar
Re: LT1 Question
Ok everyone, I have solved the problem, after three days of b/s I was not getting keyed power to the PCM. There was a fuse missing in the fuse box, she fired right up after I put in a fuse.
Thanks to all!
