![]() Join Date: Oct 2008
I have tried the search button, but haven't ran into solid infomation.
I have a 1968 c10 and want to swap my rear end from 6 lug to 5 lug. My plan is to run a posi rear end and disk brakes. The truck will be equipped with air suspension. I know board members offer disk brake brackets, but I just dont know what route to go. I dont know if there is a rear end that comes posi,disk brakes,and five lug that I could just swap. (Probably Not) What do you guys think would be the best combination? Or Where would be a good place to buy needed parts? .
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
Happy to be here
![]() Join Date: Mar 2000
Re: 5 lug conversion questions
Shane, Scoti.....anyone?
Tot Roddin'
For the '63-72 era of trucks, you will want to look no farther than Early Classic Enterprises (ECE). They offer a wide assortment of parts, including 5 lug front/rear conversion kits. Their prices might be a little higher than CPP, but you are guaranteed that if you have issues they are only a call away and will be able to walk you through the install step by step... GUARANTEED!
If you need some information about the installation of the front/rear kits, Classic Trucks just ran two features (one last month, one this month) with the install completely documented. I hope this will help with a portion of your question.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
![]() Join Date: Feb 2008
Not sure about the width but my '96 Impala SS was factory built like that - Posi, 3.08 gears, disc brakes, 5on5 bolt pattern. It was also a 4 link with coils on top of the axle. Would think it could serve your purposes well if you want to 4 link & use bags where the coils were.
BTW, changed to a 3.73 from similar year truck to get that pig off the line a little quicker. Looked at your build thread but no updates since Jan. If you have any recent pics, post them up - looks great.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) Last edited by 68C10HotRod; 03-18-2009 at 02:25 PM. Reason: Added gear info |
Thanks for your comments, I hope more people chime in to post thier opinions.
Well if the impala rear end works that would be great, but im not to sure what you mean about the width can you explain. I was thinking of doing a 2 link...Will the impala rear end still work? I have a friend that repairs wrecked cars and goes too many junk yard and he could help me find just about any part. I have not posted any pic on my build thread because I cant find my camera's battery. I guess I will buy another one soon!
if u can find a 79 caddi they came with disc brakes on 12 bolt 5 on 5 pattern, 4link and coils. probably wanna get an aftermarket posse or locker. if someone ordered a vehicle with factory possi, they did it for a reason, via racing or towing. i know if i had a factory possi id would have been hard on it.
Projects: 66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350. |
Happy to be here
He is referring to the width of the axle from side to side. If it's a bit narrower, then it might be an advantage if you want to run a wider wheel with a really deep dish.
will the later C-10 12 bolts 5 lug axles work to swap in to a '68 12 bolt?
1968 C-10 2wd, short bed fleetside, 355 Chevy, TH350, 12 bolt pegleg, '81 Camaro cowl induction on hood(I don't like it, previous owner did it), 10" wide 15"wheels. |
