Old 03-18-2009, 02:25 PM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
WTB K20 Brake Booster
Looking for a complete set up: K20 Power Brake Booster, all brackets, linkages. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-18-2009, 03:39 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: WTB K20 Brake Booster
Which year are you looking for?..
I have 67-70 C-K/20 drum brake assemblies for $50 plus shipping..
Or 71-72 C-K/20 disc brake setups for $40 plus shipping..
Livrat is offline   Reply With Quote
Old 03-18-2009, 07:21 PM   #3
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I will soon have "NEW" ones that are not available anywhere else that I know of. These are NOT rebuilts. I have all the components mocked up & measured & will test run them on my trucks before selling. It should be a couple weeks.
Both 9" DD & 11" DD OEM style, not hotrod.
PICKMUP is offline   Reply With Quote
Old 03-18-2009, 11:40 PM   #4
otsenre
otsenre's Avatar
Is there a difference between the 2x4 and 4x4? If so, what?
otsenre is offline   Reply With Quote
Old 03-19-2009, 06:28 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I posted on the fly , but I need the 71-72 set-up for DISC (prop valve) brakes. Could you post a pic of the one you have for sale?
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 03-19-2009, 10:38 AM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Not sure, I just want to make sure it fits the truck, exactly. Maybe some one else can chime in or do a forum search and see if it has been addressed.
Old 03-19-2009, 11:04 AM   #7
Livrat
Member #1049
Livrat's Avatar
otsenre both the 2WD and 4X4 versions are the same,
67-72 1/2 ton Boosters and brackets only are the same..
Master cylinder, steel lines and combination valves are 67 - 70 only (drum brakes)..
And 71- 72 only, proportioning valve, steel lines and master cylinder, (disc brakes)
67-70 3/4 tons are the same (the 67-70 3/4 ton small dia dual diaphram will work with the 1/2 tons disc brake setups.
71 - 72 3/4 tons are the same..
D.PASSMORE I will snap some pictures today at the shop and post them this eve..
Old 03-19-2009, 11:23 AM   #8
otsenre
otsenre's Avatar
Thanks, because I have one off a 72 c/30, and I have the one I need for my 72 4x4 (I hope)
Old 03-19-2009, 11:53 PM   #9
Livrat
Member #1049
Livrat's Avatar
Pics as promised..
Old 03-20-2009, 06:27 AM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Looks good, send me payment instructions. Thanks
Old 03-20-2009, 12:22 PM   #11
Livrat
Member #1049
Livrat's Avatar
PM sent
