Foolish Mortal
external to internal regulation conversion question
quick question all: going to convert from external to internal regulation for my 69 using a guide + tips I found here. The question is: do I have to worry about 'overcharging' the battery if I convert?
Thanks |
Re: external to internal regulation conversion question
if you hook it up properly you wont have to worry about a thing. now if you hook it up like a one wire alternator like the po did to my truck thats another story. if you havent read this http://67-72chevytrucks.com/vboard/s...d.php?t=119379 then i suggest you do, its how i rewired the harness for the alternator to stop overcharging.
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() |
Active Member
I assume this would not apply if you converted over to a 1 wire internal voltage regulator - if you converted to a 1 wire you can just cut the wire at the voltage regulator correct?
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
