Old 03-18-2009, 08:37 PM   #1
70k52wd
Blaze-Air
70k52wd's Avatar
Question Transporting air bagged trucks???
When transporting a truck/car with airbags on rollback, or whatever method used, what is the preferred, or better yet, correct method...Air down system? Or, air up system?
70k52wd is offline   Reply With Quote
Old 03-18-2009, 08:42 PM   #2
yotaforce
Re: Transporting air bagged trucks???
Shouldn't really matter. When a vehicle is ratcheted down, it's by the unsprung suspension components. If it lays frame or body when aired down, I would go aired up.
When life gives you lemons, make lemonade. When I was laid off, I opened my own business. So now I need a bailout to keep my business open, so I can hire more help, so I can stimulate our economy, so people can pay on their mortgage, so the mortgage company won't need a multi-billion dollar bailout!
yotaforce is offline   Reply With Quote
Old 03-18-2009, 08:44 PM   #3
big_al_71
big_al_71's Avatar
once is tied down it does not matter because it ain't moving..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-18-2009, 11:35 PM   #4
69halfton
69halfton's Avatar
i swear ive seen & answered this thread before.
if it does lay frame when its aired down, and you really dont want to worry about it... id strap unsprung compontents down, air it down until the frame is sitting on the trailer, then strap the frame to the trailer.
if it doesn't lay frame, just strap it like a normal car, just keep an eye on it to make sure it doesn't bleed down..
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-19-2009, 12:35 AM   #5
nvr_di
nvr_di's Avatar
alot of guys put 2x4's under the frame rails then air the truck out then strap it down. That way you don't have to worry about doing any damage to the body while on the trailer.
nvr_di is offline   Reply With Quote
Old 03-19-2009, 12:38 AM   #6
Shane
Shane's Avatar
transport it the same way you would a conventional suspended vehicle ... just make sure it doesn't have any leaks in the air system
Shane is offline   Reply With Quote
Old 03-20-2009, 09:14 PM   #7
70k52wd
Blaze-Air
70k52wd's Avatar
Thanks all, I appreciate the help.
