"the other guy"
u-joint help... delema
ok, i found a drive shaft that is the correct length for my application. but i need to replace the yoke with a yoke that matches my trans. the yoke on the drive shaft uses plastic injected type u-joints, the yoke i need to use takes the snap rings on each end. is there anything i can do? thanks guys
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Re: u-joint help... delema
Yes. Take the yolk and shaft to your quality auto parts shop. They can special order a u-joint. I call it a bastard joint. Sure they have another name for a mixed size joint. Or any speed shop that balances shafts n drive trains can fix you up for slightly more bucks.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
"the other guy"
thanks for the input, anyone else? maby a part #?
If you live where alot of dirt track racing is done they might just have them in stock. I know they do in my town. as far as part numbers that all depends, if there good at there job it shouldn't be that much trouble finding.
Under Construction
they are called conversion joints. I had a similar issue, took it to a driveshaft and in about 10 seconds they knew what conversion u joint i needed. 20 bucks later i was out the door.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
"the other guy"
i thought conversion joints were for mis match sizes? guess ill find out later today. thanks
Under Construction
if they dont make a convesion joint for the differnt types of yolks, they will need to cut and weld on the proper yoke, and balance the driveshaft. good luck.
You can try the guys at Pacific truck parts/Salinas drive line. They are pretty dialed on that stuff they just rebuilt my driveline after the center support bearing took a dump. They should be able to offer some help at least. The number is 831-422-4634 They can cut and re-weld different yolks end caps ect and then balance the whole thing for you.
its all about the +6 inches
take it to a drive line shop. Adding a yoke that didn't come on it will dicate getting it ballanced again.
Take it to a pro, do it once, do it right, and never have to look at it again for 10 - 20 years. |
#10 | |
That injected plastic stuff is a factory only deal. Any replacement joint you get after that is going to be a snap-ring type. They just move the snap-ring to the inner flage of the yoke like a front axle on a 4x4.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
