12-18-2002, 06:55 PM | #1 |
urban fourwheelin
Oh crap!!!!!!!!!!My truck is molding
what should I do It's everywhere. are there any moisture trapping techniques I could you until I get this thing running again?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
12-18-2002, 07:33 PM | #2 |
Fabricate till you "puke"
my truck is inside, but not a heated garage. I use card board or carpet under the truck to suck up the humidity, & have heard that if you leave the windows cracked you wont have problems with the interior........must be something to it, I havent got the door glass back in after chopping the top, & dont have any trouble with the inside getting "groaty".........
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-18-2002, 07:39 PM | #3 |
PROJECT 7DEUCE
Its a blazer thing i guess cause mine also does it ,but it also leaks like a sive when it rains......
LUKE
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-18-2002, 09:36 PM | #4 |
Registered truck nut
Go to your local RV store or Wallmart and pick up some humidity catchers. They're a little bucket type device that you add some crystals to. Or just put an electric heater in it when stored. Don't forget to unplug it when your leave, lol
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
12-18-2002, 09:44 PM | #5 |
I second leRoy on that. Also, if your seat cover and carpet are molding out on you, remove them from the truck and store in a dry place. Mold growing on vinyl and other areas? Wipe down with a mild bleach solution.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
12-18-2002, 10:42 PM | #6 |
urban fourwheelin
thanks guys, Thats kinda what I was thinkin. i'll go look for the moisture catchers tommarrow and wash it with bleach solution.
thanks again soaking wet Red72blazer
12-19-2002, 01:45 AM | #7 |
My other Love
whats weird is that my monte sat outside since 1993 and It never molded. But my 77 sat one winter and it molded. Its weird. its a good thing you don't have moss growing on your truck though
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
12-19-2002, 02:05 AM | #8 |
Designated Grumpy Old Man
I had a moisture problem in my shop. My tools were rusting, had mold growing on the walls and a lake on the floor. Broke down and bought a dehumifier from grainger. I removes 4 gallons of water a day from the shop after putting it on a timer for 8 hours a day and the mold has disappered, the tools don't rust and my lake is gone. Best money I have spent on preserving my trucks and tools.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
12-19-2002, 03:13 AM | #9 |
L.E.D. Freak
Oh well just put it to use and grow Shrooms! LOL
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
12-19-2002, 05:10 AM | #10 |
English Chevy Owner
I would definitely go with the moisture traps if your truck is outside and you need to keep the windows closed. I have used them on various cars over the years and whilst they may not stop the problem entirely they do make a difference. Just be careful with the water that collects because the crystals dissolve into it as they trap the moisture and it becomes corrosive (Alkaline) so don't let it get too full before you have to move it to empty it. If you truck is in a secure garage leave the windows open, nothing works better than airflow!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
12-19-2002, 05:11 AM | #11 |
English Chevy Owner
I would definitely go with the moisture traps if your truck is outside and you need to keep the windows closed. I have used them on various cars over the years and whilst they may not stop the problem entirely they do make a difference. Just be careful with the water that collects because the crystals dissolve into it as they trap the moisture and it becomes corrosive (Alkaline) so don't let it get too full before you have to move it to empty it. If you truck is in a secure garage leave the windows open, nothing works better than airflow! (the moisture traps work best in a sealed environment so probably won't help much with the windows open as you will be trying to dehumidify your entire garage!)
12-19-2002, 06:08 AM | #12 |
put some baking soda on a paper plate and leave it in your floorboard. and get a dehumidifier.
12-19-2002, 10:54 PM | #13 |
This sounds strange, but it really works.
Have a vehicle I have stored under a car cover for the last 3 winters. Get a pan/tub/whatever and fill it with scented kitty litter. It soaks up the moisture and the vehicle smells like new. (plus it freaks out the mice) |
