I miss this truck.
No spark, any suggestions?
The HEI in my '70 isn't throwing a spark. I drove it home from work on Monday, commented to my wife how well it ran after I replaced the fuel pump last weekend, then jumped in it Tuesday after work to run some errands, and it wouldn't even try to start.
Took the module to O'reilly, it tested good, replaced the capacitor and distributor cap with known good ones that I had in the shed. Still no spark. Any suggestions?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
Old Skool Club
![]() Join Date: Jun 2001
Re: No spark, any suggestions?
Mine did something similar, but the wire to the pick-up coil in the HEI had a break in it that would cause an open circuit when I let off of the gas and the vacuum advance moved the "breaker" plate.
After I replaced the old HEI with a new Accel HEI, no more problems.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 03-19-2009 at 02:56 PM. |
Eat My Rust
I'd test the ign wire and make sure it's hot when the key is on. If the Dizzy is mechanically sound, that'd be my guess.
![]() Join Date: Sep 2007
If it's got HEI I'd check the carbon button that contacts the top of the rotor. I've had them just vanish...LOL. it's something simple to check. Let us know what you find.
Good luck.. |
Active Member
![]() Join Date: Jul 2007
I used these sites to check mine out some time ago. Make sure you have a good ground (clean) connection at the base to the frame. Also, if you converted to HEI from points, insure you are using a non resistive wire to the distributor. If you used the old wire, it may work but can damage the module. Make sure you are using the dielectric grease on the module.
http://www.granitecityperformance.co...&print=1&page= Testing the GM HEI Distributor A no-spark condition is checked by checking the distributor for power at the connector on the side of the cap. If there is power, disconnect the electrical connector and remove the cap. Check the rotor and the cap for excessive wear. Check the coil tower for excessive wear. Remove the top plastic cap on the distributor cap. Use an ohmmeter and check the coil positive terminal to the metal case of the coil. The reading should be infinity. Check the coil tower and the negative terminal. The reading should be 900 ohms. Check the positive terminal to the negative terminal. The reading should be around 700 ohms. If any of these tests show drastically different readings, the coil is bad. If the coil is good, the cap and rotor are not cracked or worn significantly and there is no spark at any wire, replace the ignition module. |
#6 | |
![]() EDIT: By the way Tynee, Hiya neighbor! ![]() Last edited by maddog1331; 03-19-2009 at 06:06 PM. |
I miss this truck.
Hey maddog, there are indeed several members from the general area. There used to be a post where all of the kentuckians checked in. Might run a search for Kentucky. There's actually a member in or very close to Somerset named Junkyardjohn. Moved to Somerset from Las Vegas, NV a few years ago. I was as close to you as Russel Springs the other day on my way to my grandparents' house in Edmonton.
Anyway, I've pretty well narrowed it down to a the coil pickup being the most likely culprit. My question is, how do I get it out from under the mechanical advance assembly? I'm looking real hard at just replacing the entire Dizzy. It's filthy in there, even some rust from an unknown source. When I look around, I' ve found an ACCELL HEI on CL that's supposed to be almost brand new, for $80, or I can replace the coil pickup in my current unit for $40. I'm leaning towards the ACCEL unit.
Between Trucks...
Skip White HEI on E-Bay is another option.
Beat it to fit, Paint it to match... ![]() |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
This may be helpful:http://www.rustpuppy.org/ignition2/Ignition%202b.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#10 | |
I miss this truck.
Active Member
I used the rustpuppy site to rebuild mine and also this site-
http://rmcavoy.freeshell.org/HEI.html If you scroll down, he gives pn's for the items you may need. One thing I will caution you on. If the shaft is pretty much dried up or caked up with gunk and won't budge, don't force it out. Let it soak with a solvent agent or whatever you use for degreasing and slowly work the shaft out. I forced mine and moved the upper bearing. I was able to tap it back down, though. |
#12 | |
