Old 03-19-2009, 04:08 PM   #1
mole2000
mole2000's Avatar
headlight connection terminals for relay upgrade
Anyone know a source for the proper terminals for upgrading headlight connections? I'm doing the relay upgrade and this is my last piece. I have the plug from Dorman, but the actual terminals are proving problematic to reuse. All the female spade connectors I find are too small for the headlamp...
mole2000 is offline   Reply With Quote
Old 03-19-2009, 04:53 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: headlight connection terminals for relay upgrade
Try this outlet. They are quick and the product is quality
http://www.innovativewiring.com/Part...tPartsPage.htm
piecesparts is offline   Reply With Quote
Old 03-19-2009, 05:04 PM   #3
cdowns
cdowns's Avatar
Napa
Old 03-19-2009, 06:10 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Try here also: http://www.ronfrancis.com/
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-19-2009, 10:50 PM   #5
6T8&O-her-1
6T8&O-her-1's Avatar
I got one yesterday from Autozone, $5.99 I think....Works Fine. The only thing its not Double wired for use in the left headlight....But I used my left headlight socket as a Source for my Hi beam and low beam relays, and used the New plug on the left headlight so it wasn't an issue and shouldn't be for you. The Green Wire(s) are Hi and Tan wire(s) are Low beam. Black is ground. I just did mine today and tested them out tonight..Much Better!! lights are much Brighter and I get 12 volts with engine off at the headlights.
6T8&O-her-1 is offline   Reply With Quote
