Old 03-19-2009, 05:43 PM   #1
evilways
evilways's Avatar
Frame ID?
I checked my frame on the top rail driver side one is by the front tire and the other is at rear of cab area, the problem is that it is an 8 digit serial number and does not coincide with normal VIN numbers. How do you decipher this number?
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 03-19-2009, 06:17 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Frame ID?
Andy (LHM) may help you out here because we just had this discussion not long ago..... but if I remember right, those numbers don't exactly mean a thing. they could be shipping codes or date codes that aren't "decipher-able".
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-19-2009, 06:59 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Frame ID?
actually, if the numbers are right here (see photo) then they should match the second 1/2 of your VIN, otherwise, it's had a cab swap, or a new frame slipped under an old truck.
Either way, the title doesn't match the frame.
Old 03-19-2009, 07:08 PM   #4
tcb-1
tcb-1's Avatar
Re: Frame ID?
ooops, I thought you meant the number stamped into side rail of the frame, right behind the front cab mount.
see, I knew Andy would help!
Doug
Old 03-19-2009, 07:52 PM   #5
evilways
evilways's Avatar
Re: Frame ID?
Thanks guys. That is what I needed to know.
Mark
