Old 03-19-2009, 09:12 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
idle screw
i have 2 idle screws so witch one do i turn/witch way do i turn it to make my truck idle higher
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 03-19-2009, 09:46 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: idle screw
if you have a quadra jet its the one by the throttle cable
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-19-2009, 10:08 PM   #3
pokethesmot
Re: idle screw
yeah i got a Qjet but now witch way do i turn it
Old 03-19-2009, 10:09 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
Re: idle screw
turn the truck on and play with it!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-19-2009, 10:23 PM   #5
pokethesmot
Re: idle screw
well what does the other screw do
Old 03-19-2009, 10:48 PM   #6
enaberif
Re: idle screw
2 on the front are mixture screws to run the truck leaner or richer.
Idle screw is by throttle cable.
enaberif is offline   Reply With Quote
Old 03-19-2009, 11:01 PM   #7
pokethesmot
Re: idle screw
awsome how do i tune the fuel mixture with the screws
Old 03-20-2009, 12:02 AM   #8
schoolfire
schoolfire's Avatar
Re: idle screw
Counterclockwise for richer clockwise for leaner. With the idle screw counterclockwise is slower clockwise is faster.
Lots of rusty but trusty...
1978 Jimmy, 1979 K1500, 1980 C10, 1955 Belair, 1971 Camaro
schoolfire is offline   Reply With Quote
Old 03-20-2009, 01:10 AM   #9
enaberif
Re: idle screw
And you want the mixture screws to be turned the same or relatively close.
Old 03-20-2009, 07:35 AM   #10
rick1956
rick1956's Avatar
Re: idle screw
If your carb has two screws on the throttle linkage (I'm being generic here), one of them is for regular idle speed and one of them is for fast idle.
The fast idle screw (controlled by your choke) is the one that has the step cam that engages against it.
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 03-21-2009, 06:56 PM   #11
73chevyman
73chevyman's Avatar
Re: idle screw
really don't want to play with the mixture screws. there a pain to get them right. before you do any messing with them turn them to the right till it stops and count how many turns. don't tighten them up just till it stops with no butt behind it make a note for each screw. then turn them both to 3/4 to 1 1/2 turns to the left thats around about your happy medium. if you get them not right your gas milage will go in the toilet. do all your carb adjustment at running temp. i typically do 3/4 turn on both and hold my hand over the primaries if it races its to lean if it does nothing your in the ball park.. good luck
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 03-21-2009, 07:44 PM   #12
xbanone
xbanone's Avatar
Re: idle screw
BEFORE YOU TOUCH ANYTHING ON YOUR CARB! go buy a cheap vacuum gauge and tach learn how to use them to tune your carb. Just google search "carb tuning vacuum gauge" and follow instructions. It's not hard to do and its the only way short of using an Air/Fuel sensor to set everything up properly.
xbanone is offline   Reply With Quote
Old 03-21-2009, 08:21 PM   #13
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: idle screw
have adjusted by screwing the jets in until engine speed slows then back out untill best idle
powerdriver 1958 is offline   Reply With Quote
Old 03-21-2009, 09:09 PM   #14
enaberif
Re: idle screw
^ Good pictures.
I don't have screws for my jets.. I have this weird rectangular screws that I require to use some funky needle nose pliers to adjust!
