Old 03-20-2009, 01:38 AM   #1
1BAD70CHV406
What do you think about this!
Alright buys im new here but im not new to cars. Heres my build and let me know what power u think its putting down to the ground? And what time ill run in the 1/4 mile.
406 sbc (stock crank, rods and stroke)
edle AVS thunder serise 800cfm carb
edle RMP Air Gap (ported also)
xe284h comp cam (the cam kit so whole new valve trian)
1.6 not 1.5 full RR (brings the lift up to .540 int. .543 exh)
flat top 10.8:1 pistons
ported and polished factory heads with new valve job (im a collage student so new heads are going to have to wait)
long tube cerimic headers
3000 stall
Turbo 400 trans with shift kit
Z-Gate sfloor shift
Full Mallory ignition (dist., control box, coil)
all going into a 70 c10 LWB
Thanks for your thoughts
1BAD70CHV406 is offline   Reply With Quote
Old 03-20-2009, 06:17 PM   #2
1BAD70CHV406
Re: What do you think about this!
come on guys no one has any thoughts
Old 03-20-2009, 07:22 PM   #3
Ackattack
Ackattack's Avatar
I'll guess mid to low 14s if you can get traction. What gears will you be running?
Ackattack is offline   Reply With Quote
Old 03-21-2009, 04:50 PM   #4
OARNGESI
OARNGESI's Avatar
You might get better response in the racing section
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
