Old 03-20-2009, 12:15 PM   #1
ihatericeburners
ihatericeburners's Avatar
What to use on my stainless trim?
After looking up the price for new stainless steel trim, I have decided to rehab the dull trim. So... what should I paint the black with: rattle-can OR should i spry it and then clear coat the whole deal? I like the semi-gloss look but im worried that it will chip and flake if i dont clear em.
THanks
ihatericeburners is offline   Reply With Quote
Old 03-20-2009, 12:35 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: What to use on my stainless trim?
I have seen some trim that has been "restored" that is absolutely beautiful. The artisan first stripped the anodizing with oven cleaner. Then, he used a compound called Tripoli, and followed it with a fine compound. See, the material on this side trim is aluminum, not stainless. To protect the polished aluminum, I'm going to use Zoopseal, which is supposed to last for 3 years. It isn't anodizing, so it will have to be re-applied periodically as I understand the usage.
If you have small chipping/roughness, you can sand it out starting with some 600 grit and working your way up to the finer grades, like 2000 grit before using the Tripoli.
As to the paint, a semi-gloss or semi-flat would be correct if it was on my truck.
Member Nr. 2770
Old 03-20-2009, 12:38 PM   #3
cdowns
cdowns's Avatar
that trim is aluminium
Old 03-20-2009, 12:47 PM   #4
fine69
fine69's Avatar
So true.
You can wetsand it, then polish it. (high grit, like 1200grit)
Go to any auto parts store.
They have "satin" trim paint. Spray on. Looks factory.
Get some good autobody tape though. Makes it easier.
Did it on a 69 GMC i had some years ago. Had that trim. Did all 12 peices. Took me about 4 hours a day, for 2 weeks. But it turned out AWESOME.
Good luck.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-20-2009, 12:49 PM   #5
ihatericeburners
Thanks for the good information. I just spent all my spending money on the paint and wanted to cheep out on the trim and do it myself beause hey are very solid overall.
But, has anyone tried the clear-coat method and had good results?
Old 03-20-2009, 01:16 PM   #6
420am
420am's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=330642
All the info you need
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 03-20-2009, 01:21 PM   #7
420am
420am's Avatar
I plan on following that thread to restore my trim then shooting a layer or two of Eastwood Diamond Clear over them.
Old 07-30-2011, 07:34 PM   #8
Dunenutt
Newbee
Dunenutt's Avatar
I started restoring my trim. After a couple of full days, I gave up and painted it. Now I don't like it, and am going to start all over again. Good luck, it's a time consuming tedious process.
OOPS! I sure drug this one up from the dead. Need to post on the right link. DOH!
Dunenutt is offline   Reply With Quote
Old 07-30-2011, 11:06 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It's always timely to talk about refinishing the anodized aluminum trim. Calling it "stainless" is understood, but not correct.
Member Nr. 2770
