Stretched Cabs?
well im starting on planning on what im gonna do to the truck, even though i dont plan on starting the build for a few years. and since i stand 6'5 iv been thinking of stretching the cab, kinda like a crewcab build but the doors are stretched as well. has anyone done this or have pics of trucks that have stretched cabs?
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() |
blood type; Retumbo
Re: Stretched Cabs?
a few years ago I had Zumo (IIRC) do a PS of mine with a 4" stretch down the middle. it looks perfect with a long box.
Re: Stretched Cabs?
just picked myself up a cab im going to go 8 inches
1970 2wd ![]() ![]() ![]() |
Old Skool Club
![]() Join Date: Jun 2001
Re: Stretched Cabs?
Within the past 5 years, there was a feature done in Classic Trucks magazine on a '69 that had been stretched. In the article, one of GM's designers was at the show in Dallas where this truck was being shown. This particular truck was stretched between the front and rear of the cab, and I believe it had a dash from a '95-98 in it. The gist of it was that the designer who saw it commented that aside from the dash, the exterior was proportional and he thought it could have been a prototype...it was that good. The truck was built in the Dallas/FtWorth area and was painted silver. Hopefully, someone has a pix of this one and will post it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Stretched Cabs?
There was one on ebay a couple months back
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Re: Stretched Cabs?
thats funny..I was just thinking of what an extended cab might be like for my '68. Like taking the back half of a wrecked or rusted out cab and making and extended cab short bed like my 2004 is. I guess a suburban frame would be needed probably. Anyone seen an ext cab 67-72?
1968 C-10 2wd, short bed fleetside, 355 Chevy, TH350, 12 bolt pegleg, '81 Camaro cowl induction on hood(I don't like it, previous owner did it), 10" wide 15"wheels. |
Old Skool Club
Re: Stretched Cabs?
Seems like 6 inches was added to the one I described above. The bed had to shortened a like amount or a chassis had to be extended the same amount in order for the proportions to be retained. Aesthetics are a big part of any alterations. If they are right, the look will be nice. I guess the ones that make me cringe, in spite of what they are, are the crew cabs that use a second set of doors with vent windows and then have a shortened bed to keep it all on a LWB chassis. It just don't look right, to me.
#8 | |
Re: Stretched Cabs?
We were both building our cabs @ the same time & I mentioned to my buddy (who worked out of a shop in the same complex in N.Dallas) that I wanted to stretch my cab for some added leg room similar to a late model truck. I only wanted to do 3" & was thinking off adding it in the C/L of the cab as well. I would then cut the front of the bed down a similar amount to maintain a similar wheelbase vs. OE. My buddy mentioned this guy was doing something similar & took me by his shop to show me what was involved. After seeing everything that he had to do, I decided it was a buuuuuuuuunch of work for the mini-scule 3" I was after & nixed the idea. While I really like his (the owners name is Mike), the 6" stretch was a tad too much for me even though his proportions were (are) dead-on. The dash is a modified stock 67-72 that was stretched accordingly to keep the seating-to-dash dimensions close to original. I have some pics of the truck I can post up later (I'm @ work & they're on my home 'puter).
#9 | |
Re: Stretched Cabs?
Man that is an old 'chop...It took me a while to find it. There were several versions done, some by me and some by others. The properties of the file say it was created May 12 2004
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Luv the Crewcabs
Re: Stretched Cabs?
SCOTI, Is this the Truck u were Talking about?
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
Re: Stretched Cabs?
No sir (although the bed does look very similar) . . ....
http://www.classictrucks.com/feature...kup/index.html
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-21-2009 at 09:48 PM. |
muddobber
Re: Stretched Cabs?
that truck looks very similar tp the one scoti is talkin bout. got some pics in an old classis trucks mag. the bed is original style but the steps were made by using opposite side cab corners upside down under the steps
#13 |
Re: Stretched Cabs?
ive been thinkin around 6 inches, 8 max, that way the truck still looks porportioned without sacrificing the leg room i need. plus i think it would give more of an agressive look.
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() Last edited by Camper Power; 03-22-2009 at 12:12 AM. |
#14 | |
Eat My Rust
Re: Stretched Cabs?
