03-20-2009, 11:41 PM | #1 |
C10 Club Tennessee
Camaro LS1 LT1 Dual Electric Fan
Anybody using this setup?? If so I need some pics of it.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-21-2009, 05:07 PM | #2 |
C10 Club Tennessee
Re: Camaro LS1 LT1 Dual Electric Fan
ttt
03-21-2009, 07:00 PM | #3 |
Always wrenching!!
i put them on my truck when i swapped in the 5.3L
sorry not great pics. on the bottom i trimmed the plastic so that it fit into the clips like the original fan shroud did. i then just made a simple flat bracket to secure the top as you can see. nothing fancy but works great no probs. doesn't touch the radiator at all either.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress Last edited by Sicmaro; 03-21-2009 at 07:03 PM. |
03-22-2009, 09:57 AM | #4 |
Old member
That's a nice setup, I may look for one of those. What years do I need to look at for the setup? Did you use the senor's to run them or just straight wire them?
I wonder if they would fit inside the stock fan shroud, they look as though they have enough room!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-22-2009 at 09:58 AM. |
03-22-2009, 11:24 AM | #5 |
laying low
And I'm going to guess the battery has been moved to the driver side to make room for the air intake box on the passenger side?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-22-2009, 12:35 PM | #6 |
Old member
Looks like he has a battery on both sides.
03-22-2009, 03:34 PM | #7 |
Thanks for the pics! Plesae post more..... I plan to do the same.
03-23-2009, 07:25 PM | #8 |
Always wrenching!!
I added dual batteries when i did the 5.3L swap. the LS1 fans were from 98 to about 04. camaro, firebird, corvettes, gtos, the GMC/Chevy truck fans are similar also but they didnt start being installed until 2006.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress Last edited by Sicmaro; 03-23-2009 at 07:28 PM. |
03-24-2009, 05:13 PM | #9 |
Old member
Thanks for posting the year. I went by one of the local yards yesterday and they wanted $75.00 for a dual setup. They wanted to know what year and I couldn't tell them. Does this sound about right on price. He Guaranteed it also.
He also had some big small dual setups, what about those, has anybody tried them? I was thinking maybe have the big one running at temp., then the smaller one kick on only if I'm running the A/C. Any sugestions on this? Sicmaro, what is the big red block in that last picture?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-24-2009 at 05:14 PM. |
03-24-2009, 07:53 PM | #10 |
Always wrenching!!
That price is pretty good. Yeah normally the 2nd fan is wire to the a/c clutch to only come on with the a/c.
The red block is a factory junction block that is on all 4.8/5.3/6.0 truck motors. I re used all the factory battery cables.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
03-24-2009, 08:19 PM | #11 |
Old member
Thanks for the reply. I may wait until after Charlotte Auto Fair to see if I run across a deal there but this yard had about 200 differant fans hanging up in the shop area. I like the dual setup with a large & small fan.
What do you use the double batteries for?
