Old 03-21-2009, 08:23 AM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Help a Newbie!! 20's how low
I posted it in suspention but maybe I can get a quicker answer here..
here's the short version
I can grab a set of 20's cheap and found a 71 C10 SWB Stepside in decent shape...how low can I drop it (I was thinking air ride) I was going to cut one loop off the front and put jeep springs ( I have these) in the back for a quick drop (I can get thru that in a day) but then will gather the parts for air if it's worth it. I want to use the OEM front end and don't mind "adjusting" the front inners but need to keep them and a C notch isn't a big deal
this is going to be a low budget Rat rod that wil be a DD and go to my nephew next year and just want to make it kool and give him a good base line
it seems like the 2600 bags are the ones of choice anyone have any pics of them installed so I can copy the hardware for them front and rear
thanx
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-21-2009, 02:58 PM   #2
au03z71
au03z71's Avatar
Re: Help a Newbie!! 20's how low
Static -- 4" front 6" rear
I recommend bags though. And, make sure the lug pattern on the wheels matches up.
au03z71 is offline   Reply With Quote
Old 03-21-2009, 03:57 PM   #3
Hottrucks
Hottrucks's Avatar
yea I need to search or start a post to find out what fits...thanx
Old 03-21-2009, 04:39 PM   #4
OARNGESI
OARNGESI's Avatar
What year is your truck
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-21-2009, 04:58 PM   #5
Hottrucks
Hottrucks's Avatar
it's in there but it's a 70 on a 71 frame with 5 lug pattern
I did some more ssearching and it looks like ( from what I read) they will fit in the back. The wheels came off an Impalla and the back space I beleive is 5" ......
now I just need to figure out if I need to C notch and pocket the A arms neither are a big deal I just don't want to change the A arms $$$$ alos what needs to be done to clear the front inners
I think I know the answer but will this thing turn with out hitting the fender up front???
Old 03-22-2009, 08:27 AM   #6
au03z71
au03z71's Avatar
How wide are the tires? Are they 5" b/s all the way around?
Old 03-22-2009, 10:27 AM   #7
Hottrucks
Hottrucks's Avatar
yes I ahve to go measure the wheels and tires today so I'll let you know but they came off a new impalla
Old 03-23-2009, 04:06 PM   #8
Slick67
Sofa King Crazy!!
Slick67's Avatar
What size tire are you wanting to run?
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-23-2009, 04:12 PM   #9
Hottrucks
Hottrucks's Avatar
havn't gotten there to see the size but there 20's I need to check ...problem is the deal fell thoug on the truck..but I'm on the hunt now for another
