03-21-2009, 08:29 AM | #1 |
cab mount
At the back of the cab there is a cross susport, which the cab mounts to the frame. My cab, on the passenger side where the mount goes, is dented in. Is it susposed to be flat? Thanks for any help Mike
03-21-2009, 11:14 PM | #2 | |
The Older Generation
Re: cab mount
The bottom of the cross support where the rubber body mount sits should be flat. If it is dented in you will have to take the bolt out, jack the cab up, take the rubber body mount out and repair the bottom of the support. This is not easy with the cab in place but it can be done if you are, or know, a good welder. LockDoc
