03-21-2009, 03:09 PM | #1 |
Rear disc swap
i put rear disc on my 68. i bought the a kit. it fits good except the rotors drag the pad, like the pads are too thick. i dont have the brakes on my frame fully done yet. just wondering if this is normal? will they open up when i put the master cylinder on and put fluid in them?
03-21-2009, 05:20 PM | #2 |
its all about the +6 inches
Re: Rear disc swap
are you able to turn the wheel by hand? Discs are designed to drag a bit.
03-21-2009, 06:05 PM | #3 |
Re: Rear disc swap
i think so i put them awhile ago just now got around to posting. i know it rolls
03-21-2009, 06:41 PM | #4 |
Re: Rear disc swap
If you can turn it by hand, you're probably ok. Like Andy says, they're designed to drag a bit, especially when the brakes aren't bedded in yet.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
