Old 03-21-2009, 05:29 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
'63 Long Bed to Short Bed
I understand that there is an article out there that gives the specifics on cutting the frame to make a long bed short.
I picked up a roached out '63 Fleetside Longie and need the pain of another project. But I'd rather not source a new frame the way I did with my '72.
So, if anyone has the experience, or knows where the article is "parked", I'd appreciate any tips or direction.
Thanks.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-21-2009, 06:15 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: '63 Long Bed to Short Bed
Somebody just did this in the last couple months on here and took some decent pics too. I think the measures are 12'' out of the front and 8'' out of the rear......cant remember the thread.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-21-2009, 07:11 PM   #3
the lights
the lights's Avatar
I did this a couple of months ago. I took 12 inches out of the frame in front of the wheels and 8 to 8 and a half out of the back of the frame. I did the bed the same way 12 and 8, the only reason i took more out of the frame in the back was because i wanted a tighter gap between the bed and the cab. if you have your cab off you can stagger the cut so it looks like a z, but i had my cab on so i did a straight cut, and boxed the frame there. it only took a weekend to do. good luck.
the lights is offline   Reply With Quote
Old 03-22-2009, 12:01 AM   #4
protrash64
protrash64's Avatar
Hey, its like I conjured that up........'the lights' thread was exactly what I was thinking about earlier!!!!!!!!
Old 03-24-2009, 01:06 AM   #5
shrunken66stroker
shrunken66stroker's Avatar
Check out my thread. I did the same cuts on a 66. I'd be happy to answer any questions and point you in the right direction.
shrunken66stroker is offline   Reply With Quote
