03-21-2009, 07:52 PM | #1 |
How to replace the timing chain?
I'm going to be replacing the timing chain in my 70 big block truck. Can someone tell me the step by step process of doing this? how long should I expect for this project
to take if you know what you are doing? and what else should I replace while in there? Thank you guys! |
03-21-2009, 08:50 PM | #2 |
Re: How to replace the timing chain?
STEP 1 //buy service manual
STEP 2 read same
03-21-2009, 09:08 PM | #3 |
STEP 3 // don't count on cdowns
03-21-2009, 10:35 PM | #4 |
I would recomend buying a book but heres a step by step
find top dead center remove the water pump remove the harmonic balancer ( puller required ) remove the timing cover find the timing marks on cam and main sprocket LINE THEM UP TO MEET IN THE MIDDLE ( CLOSEST TOGETHER ) CHECK TIMING MARKS remove the cam sprocket by taking the three bolts off remove the crank sprocket install new crank sprocket put the chain on both sprockets roll the cam sprocket onto the cam ( dowel in slot between 2 holes) tighten 3 bolts using blue lock tite check timing marks CHECK TIMING MARKS clean gasget surfaces reinstall in reverse order |
03-21-2009, 10:49 PM | #5 |
Get a good engine gasket kit.
Get yourself a good roller timing set or gear drive. You might have to heat up the crank sprocket to help slide it on the crank. Some people heat it up with the use a butane torch, I used the boiling pan with water, so I only got it to 120 degrees. I had to, ahem..... use some BFH help. I used a plumbing pipe about the same diameter of the sprocket to tap it in. Watch the sprocket teeth, they chip off easy..... don't ask how I know this just trust me on that. Since you are doing this on your truck. Just take your time and do it with love Just remember all the $$$$ you are saving, compared to paying a shop to do the work. That always helps, when things don't come together as smoothly as one had hoped.
'72 GMC custom camper 350/350 |
03-22-2009, 12:05 AM | #6 |
the wifes new frying pan with some 30 wieght oil and a torch work well for heating the sprocket, warm until the sprocket barely turn colors and grab with a some channel locks and slide it on in a hurry. make sure the timing marks face out. have fun
03-22-2009, 12:14 AM | #7 | |
Just wondering, could you substitute the 30wt engine oil, with extra virgin olive oil?
03-22-2009, 12:17 AM | #8 |
Gone to greener pastures
And, as a side note, I'd replace the water pump since the old one is already sitting on the floor.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
03-22-2009, 12:21 AM | #9 |
good call on the water pump. and throw some mushrooms in with the sprocket to not waste the olive oil. but it would make disposal of the oil easier
