Just gettin started!
Idling Issues
I'm kinda stumped here, when i got my truck the air filter was too tall for the housing, so i finally put in the correct filter and now when i step on the gas too hard it stalls the truck out like its not getting enough air, so how do i fix this problem?
heres what i mean: ![]()
http://www.AWSurveys.com/HomeMain.cfm?RefID=kennyrounds |
The Older Generation
Re: Idling Issues
Look in the air inlet tube and make sure it isn't blocked somehow. LockDoc
Active Member
![]() Join Date: Jul 2007
Re: Idling Issues
Make sure that it is in fact the air filter by removing it. If it still stalls then you know it's either a fuel issue or maybe a timing/ignition issue.
If it runs good without it, then you'll probably need to make a change. Not sure where you would go from there. On mine I'm using the small aftermarket one that I bought from Auto Zone. Wish I had my original... |
Re: Idling Issues
yeah, it runs alot better without it, but not perfect it still stalls when i get on it hard but not nearly as much. when i cover the inlet tube it kills the truck.
it seems to me like the problem is always there but the filter amplifys it. thanks for the help
Re: Idling Issues
having a taller filter is basicly like the old flip the lid trick to increase airflow, now that your truck is getting less air than it was tuned for its running too rich and flooding out. all it needs is a quick carb tune up
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() |
GEARHEAD
Re: Idling Issues
Make sure the choke is opening fully. I found this problem with mine today. It was sputtering whenever it was accelerated under load. Choke was about 3/4 closed. Opened it up and it's running great.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Re: Idling Issues
That might be just the problem, (forgive me for the very non technical terms here because i know nothing about carbs),but it has a little round dial on the front for the choke that you turn to the left for lean, and the right for rich. So should i just crank that thing all the way to lean??
GEARHEAD
Re: Idling Issues
What you can do is warm up the engine first, then pull off the air cleaner so you can see the position of the choke, then rotate the choke assembly to full open. As it cools, it should close back up. You might check a haynes manual, etc for "how to" info.
